Thread Number: 31165  /  Tag: Brand New Vacuum Cleaners
Continuous Duty Vacuum
Post# 344517   2/18/2016 at 08:49 (2,979 days old) by ornery (Northeast Ohio)
ornery's profile picture
Good morning,
Could anybody recommend a Continuous Duty Vacuum to be used on a bench grinder? The small shop vacuums are perfect in size, cost and some are even quiet enough not to be obnoxious, but they can't take being left on for hours, which some operators are prone to doing. These grinders are moved from machine to machine on a peditstal, so can't be connected to our central vac.
I'm kicking around using timer switches or something, but need yet another replacement vacuum at the moment. Might as well purchase one that can take the abuse.
Thanks, John
Post# 344524 , Reply# 1   2/18/2016 at 10:13 (2,979 days old) by blknblu (CT)
You want a slow speed industrial vac. You should be able to find one used.
The slower speed also means it is quieter than a regular Shop-Vac.
Like this model:
Arco Wand 1000
www.industrialairsolutions.com/in...
"The Arco Wand 100 series of continuous duty industrial vacuums offer incredible durability in an ultra-compact continuous duty vacuum system. The slow-speed design enables uninterrupted 24-hour operation, day in and day out.
Powered by a TEFC motor driving a regenerative blower., the Arco Wand 1000 compact industrial vacuums are available in 1 to 3 HP and up to 200 CFM.
Rugged powder coat finish, 4 & 8-gallon capacity and quiet operation, make the Arco Wand 1000 series one of the most rugged, low-maintenance continuous duty industrial vacuums available."
Post# 344533 , Reply# 2   2/18/2016 at 11:14 (2,979 days old) by vacerator (Macomb Michigan)
bench grinder vac
A good shop vac can also work. Mine attaches to my table saw. Those with larger work shops buy the belt driven blower type with he large cloth bag.
Post# 344577 , Reply# 3   2/18/2016 at 19:18 (2,979 days old) by ornery (Northeast Ohio)
Thanks for that info and link about the ARCO. I found a ARCO 12-S on Ebay for $3,500.00. They look a little large and very pricey. I just ordered a new grinder and 15 minute timer switch from Zoro. Still not sure which vacuum I'll get, but it will probably just be a cheap shop vac. I doubt anybody will sign off on anything over $500.
