Thread Number: 31052
Dyson DC25 Post motor filter popping loose. |
Post# 343103   2/7/2016 at 14:44 (2,998 days old) by joerwheeler (USA)   |   | |
My 5 year old well maintained DC25 has just started having an issue where the post motor filter (inside the ball) won't stay clipped in.
I can't see any broken clips or any other cause for this. Ironically, a neighbor who has a DC25 said that hers does this as well, so she runs without the post motor filter. Anyone had this issue? Is there a fix besides getting a new filter? Does anyone run theirs without the filter in place? To me,except for getting motor carbon dust into the air, and inside the ball, it shouldn't hurt the motor, and in fact may allow it to run cooler (the motor has always run hot anyway). Besides the obvious "don't buy Dyson's" or "DC25's suck is why this is happening" responses, anyone having some personal experience or advice on what can be causing this issue please chime in. |
Post# 343169 , Reply# 2   2/8/2016 at 14:36 (2,997 days old) by joerwheeler (USA)   |   | |
Kinda what I though the answer would be. I did wash the filter again thoroughly and used it for about twenty minutes and it stayed attached. But I'll have to see if running it longer, building up more heat, will cause it to pop off again. Perhaps I let it get a little too dirty and washing it will solve the problem, but we'll see. But thanks for the help!
Post# 343277 , Reply# 5   2/9/2016 at 15:43 (2,996 days old) by joerwheeler (USA)   |   | |
I suspected that the filter may only work for a short while and that the pressure is popping the filter off at some point. This makes perfect sense! My other theory about the heat buildup contributing to it probably has no bearing. Thanks for the info, as I know that others have far more Dyson cred than I do. I will keep running it and see if perhaps I got it cleaned enough, because I know I let it go far too long this time, due to putting off cleaning the filters for another day. We'll see if the filter is used up or still can be cleaned and run for a while longer. Thanks again everyone!
Post# 343488 , Reply# 6   2/11/2016 at 09:51 (2,994 days old) by beko1987 (Stokenchurch, United Kingdom)   |   | |
The clips are known to move with age and not clip back in again, I've replaced them with 100% success every time. Qualtex (in the UK) re-designed their post motor filter retaining clip to dial this out, and every one of the 4Home branded ones have been fine. If America has old stock this may still be an issue though |
Post# 344050 , Reply# 7   2/14/2016 at 18:50 (2,991 days old) by Parwaz786 ( )   |   | |
Purpledefector, how did you know my name? |
