Thread Number: 30857
HELP....My Hoover Celebrity QS retractable cord needs fixing |
Post# 341391 , Reply# 2   1/15/2016 at 15:44 (3,020 days old) by Durango159 (State College, PA)   |   | |
I have a Celebrity IV Elite and think I know your problem. There is a brake arm that is on a spring and puts tension on the winder to hold it still unless the break arm is pushed on. The pad at the end of the brake arm is probably very worn. If you can put a rubber or foam or talk to someone that does servicing and perhaps they know the best material to use to replace the worn brake pad on the brake arm!
With out seeing your actual machine, that is my guess of your problem and solution. Here is a photo of my style machine.
