Thread Number: 3057
Kirby Sentria Review and Design Issues... |
Post# 33959 , Reply# 4   3/3/2008 at 23:04 (5,888 days old) by swingette ()   |   | |
too bad about the belt lifter. that should be one of the most durable parts on a Kirby. they should plan for rough treatment of the lifter. looking forward to the vids, matt! |
Post# 34029 , Reply# 9   3/4/2008 at 16:26 (5,887 days old) by vintagehoover ()   |   | |
cool video! I do like the styling of the Sentria. |
Post# 458204 , Reply# 10   11/27/2022 at 02:48 (507 days old) by Rowdy141 (United Kingdom)   |   | |
I have three Sentria and one Sentria II.
The LED headlights are faulty on three out of four. Kirby redesigned their modular LED Control Board but this hasn't improved reliability. They still fail after a very short time. They're expensive items here in the UK. £36 per unit. And they require a complete strip-down to replace. Not something your average consumer should expect to do. The Sentria seems to have been designed entirely with a French Curve. No straight lines using a ruler. Whilst this gives it an ergonomic look, it does little for practicality or comfort. The hand-grip is so sleek it's difficult to hold on to when pulling the machine backwards and maneuvering the machine to crab sideways. Kirby redesigned the Sentria cloth bag zipper. Going from a staight up & down zip on early Sentrias, it now incorporates curves top and bottom. These zips don't work well going round curves on the soft, flexible bag. You need two hands to get the zip started each time. The belt-lifter is much too flimsy. As already mentioned. All-plastic with a small metal pin. This needs to be made of aluminium. Belt-lifters also suffer from cracking around their central screw. Either from normal use or from over-tightening of that torx screw during reassembly. Adding a thin washer front and back make this a better, more durable fit. Kirby has already discontinued the chrome-finish belt-lifter. Only available in Avalir black from now on. The mains lead is a fixed length between its two moulded plugs - one at the machine end, the other for the wall outlet. If the lead was half a metre shorter (or half a metre longer) the flex would sit neatly around both cord hooks. Instead it hangs awkwardly, swinging into the machine every time you move the vacuum. Coloured main flexes look great when our machines are new, but when you need to replace one, there's only ever black or grey. Nothing spoils the look more than a mismatched mains lead. Precarious 'wing' on the hose-end. The extended wing that operates the safety switch should have been a more integral design. Its only a matter of time before this snags on furniture and breaks, or is accidentally stepped on. Tool caddy is still basically an upturned bucket with the side cut away. There's still insufficient space to store all your tools neatly. It could easily have been designed to accommodate each tool individually and to house your interchangeable heads (polisher, shampooer) in the base. This is a legacy design left over from the Heritage I. |
Post# 458207 , Reply# 11   11/27/2022 at 09:05 (507 days old) by Kirbyg6 (York)   |   | |
Post# 458232 , Reply# 12   11/27/2022 at 21:41 (506 days old) by panasonicvac (Northern Utah)   |   | |
Personally, I like the Sentria. But not as much as the older Generation models. And honestly if I had to buy a Kirby today to use for myself, at least from the Generation series, it would be the G6. The G6 is much more nostalgic to me, one of my top 3 favorites from the Generation series. I like the looks of it and the design more than the Sentria including the Avalir. I can still buy the matching black colored parts for it as of today since the Avalir is black as well. And I can use paper bags for it. Unfortunately Kirby doesn't sell genuine paper style F bags and I wish they did as I prefer using paper bags for my Kirbys.
Post# 458237 , Reply# 14   11/27/2022 at 22:56 (506 days old) by panasonicvac (Northern Utah)   |   | |
Post# 458324 , Reply# 15   11/30/2022 at 17:21 (503 days old) by human (Pines of Carolina)   |   | |
Rowdy141 wrote:
Kirby redesigned the Sentria cloth bag zipper. Going from a staight up & down zip on early Sentrias, it now incorporates curves top and bottom. These zips don't work well going round curves on the soft, flexible bag. You need two hands to get the zip started each time. I reply: The curved zipper actually made its debut on the G7 (aka 'Ultimate G'). From the standpoint of functionality, I can't tell a whole lot of difference between any of my G-series Kirbys. They make a few cosmetic changes from model to model, but it's really the same machine. The one I seem to use the most is my G7 Diamond. I do believe Kirby is in an unwinnable situation—with itself on the second-hand market. Used Kirbys in decent shape go for very little. Thrift shops sell G-series Kirbys for about $50 with accessories and $30 or less without them. And they will last for decades with proper care. I would certainly be sad if Kirby went belly-up, but the second-hand market would continue to be flooded with them for years to come and I've got enough Kirbys to last a lifetime, anyway. |
Post# 458423 , Reply# 17   12/5/2022 at 10:31 (499 days old) by Rowdy141 (United Kingdom)   |   | |
I agree. Kirby is competing with the Kirby secondhand market.
Amstrad stifled their secondhand market in monitors and printers from day-1. If you upgraded to a colour monitor, you still had to have the old monochrome one connected and powered-up. Same with their printer. Kirby have redesigned the Emtor, Cloth bag, Paper bag, Hose ends. Brushroll... If you consider these moves built-in obsolescence, with no backward compatibly, it makes marketing sense. |
