Thread Number: 30522
Royal 235 Information Appreciated |
Post# 338248 , Reply# 1   11/28/2015 at 22:44 (3,070 days old) by hygiene903 (Galion, OH)   |   | |
Nice find, and I believe the 235 is a pre-war model. However, they didn't change much over the years and you'll find that later models are quite similar, and there are a few things you need to know. First, if you look at the motor housing you will find two oil ports, one in front just behind the fan case, and the other toward the back. They may have either metal or plastic caps on them, the plastic will have a slot for a screwdriver. Remove the caps, and put about 6 drops of 3 in 1 ELECTRIC MOTOR oil in each port. This is NOT regular 3 in 1 oil, but a special formula they make for electric motors. It should be available at Home Depot, Lowe's, or your local hardware store. After this first oiling (which should be done ASAP, as you don't know when the previous owner last oiled it), it should only need oiled about once a year.
Next is height adjustment. You will notice a knob in the back, above the rear wheels. Turn it clockwise to lower the nozzle, counterclockwise to raise it. Raise the nozzle a bit, then turn on the machine and lower the nozzle gradually until you hear a change in the sound of the motor, then the nozzle will be set for your carpet. As for how well it cleans, a Royal in good condition will clean as good as a Kirby (if not better). To see the cleaning action at work, sprinkle a little salt on the rug, turn on the Royal, and as you get within about an inch of the salt you'll see the granules "dance" from the vibration of the brush roll and the suction drawing the granules toward the nozzle. As for bags, it looks like you have a shakeout bag. Good news is no bags to buy, bad news is you have to empty it. First, unhook it from the handle, then twist the collar where it attaches to the fan case outlet. Spread some newspaper on the floor, slide the clamp off the top of the bag and place the open end of the bag on the papers, and hold in place gently with your feet, then grab the collar and shake gently. The bulk of the dirt should fall out onto the paper. Then move to another spot on the paper and shake vigorously, that should take care of the rest. However, if there's a zipper on the back of the bag, then it does take disposables, and Eureka F & G bags work well, are readily available, and fairly cheap. Here are pics of some of my vintage Royals. Pic one is a group pic of a model 153, a 157 hand vac, and a 189. Pic 2 is another 189, and pic 3 is a 215. Although you can't tell from the front, the 153 actually has a zipper (disposable) bag on it. Jeff |
Post# 339557 , Reply# 5   12/18/2015 at 01:16 (3,051 days old) by hygiene903 (Galion, OH)   |   | |
Glad I was able to help. As for the oil, the 3 in 1 Electric Motor Oil is made specifically for motors and would be your best bet. It should be available at your local hardware store, or home improvement stores such as Home Depot, Lowe's, or Menard's. Regular 3 in 1 will work in a pinch, but not as well as the 3 in 1 Electric Motor oil. Not sure about the sewing machine oil, but seems I have heard of people using it before.
I agree with rugsucker that a tank or canister, or upright with attachments would be best for your brick floor. However, if you want to use the Royal for it, adjust the nozzle height to where the bristles of the brushroll barely touch the floor, but high enough that the bottom plate does NOT touch the floor. That should work pretty well. Jeff |
Post# 339578 , Reply# 6   12/18/2015 at 12:29 (3,050 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
