Thread Number: 30250
Kirby 516 Rear Bearing - Shield? |
Post# 335792   10/17/2015 at 12:09 (3,111 days old) by champamp (Louisville, KY)   |   | |
Is it supposed to have a shield? The front says Made In USA, and then tiny numbers I can't read.... I haven't cleaned it yet, but it turns well. Other newer vacs have bearing shields? |
Post# 335815 , Reply# 2   10/17/2015 at 20:15 (3,111 days old) by champamp (Louisville, KY)   |   | |
So it's likely that this bearing once had a shield....I should probably get a new one. Thanks. |
Post# 335836 , Reply# 3   10/18/2015 at 02:45 (3,110 days old) by bikerray (Middle Earth)   |   | |
If it's any help the front bearing is a 87500 and the rear bearing is a 87007.
The old rear bearings were enclosed on the side facing the commutator and open on the other side. Then there was a grease shield up against the open side of the bearing and a washer with spring fingers that went in the housing. |
