Thread Number: 30232
Cordwinder HELP! |
Post# 335641   10/13/2015 at 16:22 (3,116 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 335643 , Reply# 1   10/13/2015 at 16:48 (3,116 days old) by rugsucker (Elizabethton TN)   |   | |
Step 1--Be aware the springs can cut you badly and quickly!! Step 2--Decide to not fix or use EXTREME CAUTION. Step 3--Consider finding used part or pats machine. Elux 1205 and newer are easiest to fix with caution & knowledge.Many others are best to replace. |
Post# 335645 , Reply# 2   10/13/2015 at 17:13 (3,116 days old) by blknblu (CT)   |   | |
On the Super J and similar, there is a steel coil spring that can weaken over time. Yours is probably similar. Time to find a replacement. Pic shows one from an Olympia One, arrow points to the coil spring.
Post# 335665 , Reply# 3   10/13/2015 at 21:35 (3,116 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 335667 , Reply# 4   10/13/2015 at 21:51 (3,116 days old) by bikerray (Middle Earth)   |   | |
