Thread Number: 30211
/ Tag: Vintage Floor Polishers/Floor Care Products
Kirby 509 Project |
Post# 335440   10/8/2015 at 21:20 (3,094 days old) by chicagomike (Plover, WI)   |   | |
4
Post# 335451 , Reply# 2   10/9/2015 at 01:11 (3,094 days old) by electrolux137 (Los Angeles)   |   | |
~ I thoroughly enjoyed these videos!! You did a beautiful job on the machine and I know Walker must have just been beyond thrilled. A great postscript to these videos would be one of Walker when he received the machine and unboxed it, seeing it for the first time! btw ... Did you know that on the early Kirbys (through the 2C), the numbers on the height adjustment were filled in with red paint? Also, on the early machines through the 2C, there were thin, red-painted washers inside the screws for the wheels? Also that on the early machines (until the Model 4C), the rear wheels were narrower than the front wheels... when the company decided to go with all four wheels the same diameter on the 4C and thereafter, they discovered the rear wheels didn't quite fit on the Sani-Emptor side and tended to rub against it. So what did they do ... they turned the rear wheels "inside out" so that the hollow side faces out. That way, the wheel on the right side doesn't scrape against the bottom edge of the Sani-Emptor. You can clearly see this in the instruction bookets, and they have been that way on every original-condition 505~515 I've come across. I've always thought they looked odd that way and sometimes change them around, even though it's original to have them backward. This post was last edited 10/09/2015 at 01:38 |
Post# 335457 , Reply# 3   10/9/2015 at 10:53 (3,093 days old) by kirbymodel2c (Nottingham, England)   |   | |
Michael. The videos you've made are very good. It must of took a while to upload them.
Hi Charlie, As far as I'm aware the Kirby 4C still had the thin wheels at the back. The 505 was the first to have all four wheels the same thicker diameter. My 4C has the same wheel set up as Bills "Eurekastar's" 4C.
Reply 3 in thread 24772
http://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?24772
James
Post# 335458 , Reply# 4   10/9/2015 at 11:31 (3,093 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 335460 , Reply# 5   10/9/2015 at 11:41 (3,093 days old) by electrolux137 (Los Angeles)   |   | |
Post# 335472 , Reply# 6   10/9/2015 at 14:58 (3,093 days old) by kirbymodel2c (Nottingham, England)   |   | |
I've just been looking at the 4C manual and nearly all the pictures in it are of the 2C with all four of the wheels being the same but the thinner style. Even the complete "4C" pictured on page 4, fig 1 shows the back of the 4C power plant being belonging to a 4C but showing it with the same style fan casing as the 2C. As it edging looks flat and not curved as it should be. I'm guessing that's because the designers of the manuals drew the pictures and altered/recycled the pictures as needed. The public generally wouldn't be able to tell the difference anyway. Just us collectors
James |
Post# 335477 , Reply# 7   10/9/2015 at 16:04 (3,093 days old) by human (Pines of Carolina)   |   | |
Post# 335572 , Reply# 8   10/11/2015 at 17:52 (3,091 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 335603 , Reply# 9   10/12/2015 at 13:15 (3,090 days old) by CharlesKirby66 (Manteca, CA)   |   | |
