Thread Number: 30142
Hoover 62 |
Post# 334701   9/27/2015 at 22:38 (3,125 days old) by cocoaboo48 (ny 11418)   |   | |
My Hoover 62 has a lack of suction with the hose connected. |
Post# 334709 , Reply# 1   9/28/2015 at 00:40 (3,124 days old) by hygiene903 (Galion, OH)   |   | |
There is nothing wrong with your 62, this is actually a common problem with all Hoover uprights with the hose connection on the side, due to the fact that the hose connection is not completely sealed--you are also drawing air through the nozzle. With the earlier "coffee can" models, the bottom plate and belt were removed and the hose connector was connected directly to the fan housing, but when the side connect models were designed, suction power was sacrificed to make hose connection easier for the user.
Attachment suction was improved a little with the Convertible as it kicked up the wattage of the motor when the converter was plugged in. However, it was still not completely sealed, until the front connecting "suction seal" converter became available with the later convertibles. Hope this information is helpful. Jeff |
Post# 334712 , Reply# 2   9/28/2015 at 01:54 (3,124 days old) by tolivac (Greenville,NC)   |   | |
Another problem with these is the very narrow,small opening on the converter-remember uprights work on AIRFOW-not suction-so the airflow is choked by the converter.Think of a Kirby with a small opening converter for its hose! |
Post# 334782 , Reply# 4   9/29/2015 at 07:53 (3,123 days old) by HOOVER61 (baltimore maryland USA)   |   | |
LEARN SOMETHING NEW EVERYDAY I TESTED MY 61 FOR TOOL SUCTION AND I NOTICED THE DIFFERENCE WITH THE HANDLE LOWERED AFTER 50 YEARSI LEARNED SOMETHING I N E V E R KNEW HOOVER 61 |
Post# 334785 , Reply# 5   9/29/2015 at 10:28 (3,123 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 334890 , Reply# 6   9/30/2015 at 12:40 (3,122 days old) by HOOVER61 (baltimore maryland USA)   |   | |
JOHN I HAVE N E V E R SEEN THAT IN ANY OF THE HOOVER MANUALS I HAVE HOOVER 61 |
Post# 334896 , Reply# 7   9/30/2015 at 14:19 (3,122 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 335140 , Reply# 8   10/3/2015 at 17:45 (3,119 days old) by cocoaboo48 (ny 11418)   |   | |
Thanks guys for all your advice. I will try your hints soon and I will post my findings. |
