Thread Number: 29596  /  Tag: 50s/60s/70s Vacuum Cleaners
Compact C9
Post# 330033   7/24/2015 at 16:22 (3,197 days old) by compactc9guy (Bathurst NB)
compactc9guy's profile picture
Hello every one i own a Compact Electra C9 and i bought a new exhaust filter braket or mounting plate if you will how do i go about remooving the old screws holding the braket ? This is the first time i tackle this project link below to indicatethe part im working on .Im talking about the exhaust filter ring that holds the black round exhaust filter how do i install a new one as the breaket has broken off leaving behind the metal rivets or screws .
CLICK HERE TO GO TO compactc9guy's LINK on eBay
Post# 330657 , Reply# 1   7/31/2015 at 16:14 (3,190 days old) by compactc9guy (Bathurst NB)
any one ?
I am replacing the exhaust cap ring that holds the black round exhasut filter on the outside on my C9 electra i have to remoove the screws or metal revits and how do i d o it whit out damaging the maching thansk in advance .
Post# 330684 , Reply# 2   8/1/2015 at 07:10 (3,190 days old) by Packardmanken (atlanta ga)
Compact 9 rear filter removal
Compact9guy!
I recently did the same with my compact. Seems that the orignal ring is frequently broken from bumping or mis-handling. I found this out after talking with Tri-stars office. The gave me instructions on removal and replacement. It is very easy. I used the appropriate sized drill bit and drilled out the rivets. Careful to vacuum out the metal shards before going any further, I then mounted the new ring and used a "pop-rivet" gun to attach it. If you are un-familiar with the tool, any hardware or auto store will have one with an assortment of rivets. Just find the right size rivet and give the gun a good squeeze and you are done! These tools are pretty cheap and I have never run out of the rivets that came with the original purchase. Good luck!
CLICK HERE TO GO TO Packardmanken's LINK on eBay
Post# 330751 , Reply# 3   8/1/2015 at 20:29 (3,189 days old) by compactc9guy (Bathurst NB)
Packardmanken Thank a bunch!!
Il do just that when i get my pay ill fix up my C9 Compact vacuum .
I rebuild the power brush got the original metal floor tool the rear filter is the last thing i needto do and it will be complete!!
I wanted a compact for so long now
