Thread Number: 29537
Daily Vacuuming Results |
Post# 329609   7/18/2015 at 21:42 (3,197 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
I thought people might like my new daily results topic. I vacuum each day in the house. I pick a new room each time, vacuum it, then immediately go over it with a bagless vacuum to see what the regular machine missed. Feel free to do the same and post on it. The results are interesting. I will always go over it with my Eureka Quick-Up.
Vacuum for Today: Kenmore Progressive 300 |
Post# 329630 , Reply# 1   7/19/2015 at 07:15 (3,197 days old) by cuffs054 (monticello, ga)   |   | |
Wow, that's alot of dirt for the KM to miss. Are you sure it's working correctly? |
Post# 329633 , Reply# 2   7/19/2015 at 08:25 (3,197 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 329644 , Reply# 3   7/19/2015 at 12:43 (3,196 days old) by Durango159 (State College, PA)   |   | |
If that is a stretch belt, then it really needs to be changed.
The Kenmore and any other vacuum should beat the pants off that lightweight Eureka Quick Up stick vacuum. The air flow is very limited and the bristles on brush roll are long but soft as thread and spin slow compared to regular market bagless vacuums. |
Post# 329645 , Reply# 4   7/19/2015 at 13:03 (3,196 days old) by Turbo500 (West Yorkshire, UK)   |   | |
Post# 329656 , Reply# 5   7/19/2015 at 15:21 (3,196 days old) by sptyks (Skowhegan, Maine)   |   | |
That's not ALWAYS the case Chris. When I vacuum my living room with my Kirby Sentria and then immediately follow behind with my Hoover WindTunnel Air which I completely washed out the bin and filter with soap and water the night before, I find only a few, maybe a dozen small grains of sand or grit in the bin. |
Post# 329669 , Reply# 6   7/19/2015 at 21:17 (3,196 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 329679 , Reply# 7   7/20/2015 at 05:39 (3,196 days old) by Turbo500 (West Yorkshire, UK)   |   | |
4
Stan, given the Kirby's exceptional carpet performance, that's to be expected. But if you went over with the Kirby again, you'll still get out more dirt that the first pass with the Kirby and then the Windtunnel left behind, and then again with Windtunnel etc. You could go on vacuuming forever really |
Post# 329680 , Reply# 8   7/20/2015 at 05:40 (3,196 days old) by Turbo500 (West Yorkshire, UK)   |   | |
Post# 329688 , Reply# 9   7/20/2015 at 08:33 (3,196 days old) by cuffs054 (monticello, ga)   |   | |
Amazing! it's almost like the same pile of smutz that came up on the first test. I think you're living over a ancient burial ground... |
Post# 329703 , Reply# 10   7/20/2015 at 13:04 (3,195 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
This is the first mistake a lot of people make with owning a bagged and a separate bag-less vacuum - cooing over what the bagged machine misses just because you can see and capture what the bag less vacuum picks up.
I’m not convinced because I also own a bagless vac and a bagged vacuum. Just because you can't see the dirt in the bag doesn't mean it isn't there. Particularly high filtration dust bags where dust goes behind the layers of the bag's design to absorb and remain naked to the eye. I agree with what Chris says but also for the fact that you can keep convincing yourself that your carpet is clean when in reality it actually isn't. Airborne dust and dirt flies around and due to the science of gravity means it ends up in the carpet again. Same kind of result will be found when using a bagless vacuum first and then another bagless vacuum afterwards, or even just a mechanical sweeper - there will always be dirt or dust due to what is in the air. |
Post# 329712 , Reply# 12   7/20/2015 at 13:56 (3,195 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 329720 , Reply# 13   7/20/2015 at 14:23 (3,195 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 329725 , Reply# 14   7/20/2015 at 15:19 (3,195 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
If you want a shocker, get yourself one of these. I buy one of these every couple of years. It shocks me every time I switch it on in rooms with carpets and when the "clear" water gets cloudy with dirt and dust. The kitchen is where mine is located now since my old cooker hood broke. So much cheaper, less noisy and uses less power.
