Thread Number: 29458
Squeaky rear wheels on a Electrolux EPIC Series 6000SR |
Post# 328830 , Reply# 1   7/8/2015 at 13:09 (3,208 days old) by Kirbysthebest (Midwest)   |   | |
Plain Carnauba Car wax on the axle and squeeks be gone. You also have less worry about the WD harming the wheels and leaking onto the carpet. |
Post# 328832 , Reply# 2   7/8/2015 at 13:41 (3,208 days old) by BikerRay (Middle Earth)   |   | |
Electrolux Epic 6000SR is a plastic body, the last time Electrolux had an axle was the Model L. Each wheel is held on by a clip on the inside of the body. Once you get the body apart just spread the clip apart and slide the wheel out. Then you can clean the wheel and opening in the body in case there is crud in there. Lubricate with vaseline slide the wheel back in and put the retaining clip back on the wheel.
Post# 328835 , Reply# 3   7/8/2015 at 14:43 (3,208 days old) by Kirbysthebest (Midwest)   |   | |
My advice about the axle was for the power nozzle. that was where I dealt with my most recent squeek, and I failed to read into the post that it was the machine itself. I stand corrected. |
