Thread Number: 29451
My Dirt Devil |
Post# 328779   7/7/2015 at 18:17 (3,214 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Ever since I moved to my youngest brother's house, we didn't have any vacuum cleaners, although my father sometimes lends me his bagless upright Bissell. But then, earlier this year, I received my grandmother's vacuum cleaner when she moved to a retirement home.
It's cheap Dirt Devil canister like the ones that could be found at Walmart. It does a poor job at cleaning the carpets since it's a straight-suction canister. I went to the Vac Shack store in Ottawa and when I asked the shop owner about getting a turbo brush for my product, he told me that I would need a vacuum with a motorized nozzle to properly clean carpets. Although the model I got is not my favorite, I decided to keep it until the canister malfunctions. I plan is that when I'll have enough money, I'll get better attachments to replace the useless ones and also get a Simplicity Freedom (or a similar kind of product from Riccar or Fuller Brush) for the carpets. Would that be a good plan?
Post# 328791 , Reply# 1   7/7/2015 at 20:42 (3,214 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
I hazard a guess that the dealer said that for securing a sale but on the other hand PN's are great for deep down dirt removal in my experience.
If your Dirt Devil has a small bag capacity and concentrated suction flow, it will do a great job with an air driven turbo brush fitted to it. Don’t expect deep down grit removal, but rather basic top soil removal, better than suction only in my experience. Just depends on what brand you get based on the measurement of the actual tube - if it is 3.2cm/32mm then a lot of tools already exist on the market, if it s 3.5cm or 35mm, Bosch friction fit style turbo brush might do, if you can get one in Canada. By the looks of your close up photo I may be correct that it looks like 3.5cm/35mm fittings but my eyes might be deceiving me. Check Amazon in your country. There are a few main sized turbo brushes you could buy for this model. |
Post# 328792 , Reply# 2   7/7/2015 at 20:43 (3,214 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Here's the canister's underside (with the tag). I wanted something made in a country other than China, but like I said earlier, I'll keep this thing until it malfunctions.
Post# 328797 , Reply# 3   7/7/2015 at 21:41 (3,214 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Thank you, Sebo Fan, for your advice. Now I'll say more things about the vacuum.
Here's the canister with the open lid, the bag with a part attached to it and the bags' container bag. I had a hard time finding more bags that are compatible with the machine, but eventually, my father went to the Chapman Boutique store to order the bags. Some days later, I got them and they fit. I'll be posting a link to the website about the store, but it's in French only. CLICK HERE TO GO TO moderneezer's LINK |
Post# 328800 , Reply# 4   7/7/2015 at 22:05 (3,214 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Ah those bags fit the Hoover Studio which is basically a Morphy Richards vac in Europe as well as one made by Electrolux. They're all made in China - but they are actually robust and were common in the 1990s.
They should have 32mm tubes, but it might be different being a Dirt Devil - take a ruler and measure the end of one of the tubes opening diameter. |
Post# 328812 , Reply# 5   7/8/2015 at 07:56 (3,213 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Here's the hose handle and the valve. The connection diameter is 1.25 inch (3.175 cm).
And Sebo Fan, do you think a lot of the vacuum cleaners in the British market use bags that are similar to the ones in my pictures? |
Post# 328819 , Reply# 6   7/8/2015 at 10:08 (3,213 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Here's the telescopic wand. It connects to the hose by friction fit and it looks durable. I might keep it when the canister gets defective.
Post# 328820 , Reply# 7   7/8/2015 at 10:21 (3,213 days old) by Turbo500 (West Yorkshire, UK)   |   | |
Not so much now, but certainly a few years ago, there were a lot of cleaners of the same design but with different branding.
Hoover Studio Morphy Richard Jazz Goblin Ace Dirt Devil Compact Electrolux "The Boss" Compact JMB 1300 Those are just the ones I can think of off the top of my head that were all, pretty much, the same cleaner using the same bags. |
Post# 328847 , Reply# 8   7/8/2015 at 17:52 (3,213 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
I used the floor brush to clean the kitchen floor and look at all the hair that sticks to the bristles. Can any of you give me a suggestion about which floor brush I should get that doesn't get stuck to the bristles?
Post# 328848 , Reply# 9   7/8/2015 at 18:29 (3,213 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Post# 328854 , Reply# 10   7/8/2015 at 20:15 (3,213 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Here's the upholstery nozzle. In the last of the four pictures, the nozzle is attached to the hose while the canister's turned on. Look what it's capable of doing.
Out of all the attachments I got with the canister, the upholstery nozzle is the only one I consider keeping. The others are all junk. |
Post# 328891 , Reply# 12   7/9/2015 at 11:19 (3,212 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
The hard floor tool you've shown is effectively the same ones that even German brands like Bosch, Miele and SEBO produce, even though SEBO also have their own design. The castle cut always gets clogged with dust regardless of the brand; so its not just Dirt Devil that has this issue.
It is mid priced. CLICK HERE TO GO TO sebo_fan's LINK |
Post# 328931 , Reply# 13   7/9/2015 at 22:14 (3,212 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Here's the dusting brush. It's useless as it doesn't even fit with the hose. It's most likely for a different vacuum cleaner. I recently got different dusting brushes from different stores but I'll discuss them in another thread.
And by the way, thank you for the advice on turbo and floor nozzles, Sebo fan and Vac-O-Matic!
Post# 328962 , Reply# 14   7/10/2015 at 10:11 (3,211 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Dusting brushes are a constant pain in the backside in my experience; so many brands copy each other and do short stubby bristles. Even my Miele dust brush has a wonderful wavy rubber inner central coated hole that can "scrub" the bristles clean when dust gets clogged on the outer bristles but I end up having to pull the stuff off the bristles in order to get the brush clean again.
This is one reason to why the SEBO brand don't include dust brushes as standard. The company offer them mainly as an optional cost extra tools bar on the D series canisters because owners wanted a dust brush as standard, worldwide. SEBO's cost optional ones have longer bristles and always built around a triangular shape which I don't tend to clean that much of. That's not to say they're perfect though - they also need constant cleaning when the bristles get caught up in the suction hole! But it depends largely on the owner - they're not supposed to use the high suction setting - if applicable - where dust tool usage is concerned. A lot of owners on here have slated the German/European vacs for dust brushes in general. I know in the U.S many vacs have better bristles, but even I tried an American dust brush not so long ago and found that it clogged up just as badly as the European ones. Dyson do a flat brush tool - its a good design but it is far too big to me, to be of any use. The one you've shown doesn't look like it belongs there. It is possible that the crevice tool you should have got should have had a snap down brush over the crevice opening but the supplier of the vac probably discovered that no dust brush was standard, and put in that other "lighter grey" one as a freebie. Certainly if it was part of the tool kit, it wouldn't be a different colour. |
Post# 329006 , Reply# 15   7/10/2015 at 20:39 (3,211 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
It's true that the bristles of all or almost all dusting brushes do need cleaning once in a while.
Now here's the crevice tool. The attachment does fit with the Dirt Devil hose, but I'll leave you all to guess why I consider it junk. I got more crevice tools but that too, I'll make a separate thread about that. |
Post# 329021 , Reply# 16   7/11/2015 at 02:56 (3,211 days old) by tolivac (Greenville,NC)   |   | |
Just use the hose end to clean the bristles of dust brushes and floor tools-works OK for me. |
Post# 329030 , Reply# 17   7/11/2015 at 08:07 (3,210 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
I might try that, Tolivac.
Here's the tool caddy. I don't have much to say about this. |
Post# 329045 , Reply# 18   7/11/2015 at 13:54 (3,210 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Post# 329060 , Reply# 19   7/11/2015 at 17:35 (3,210 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
Post# 329186 , Reply# 20   7/13/2015 at 09:38 (3,208 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
I already created a link ages ago about "HOPELESS ACCESSORIES," of which you can add to that thread if you wish.
(Click on link) You may find tools that you've shown here, already there. CLICK HERE TO GO TO sebo_fan's LINK |
