Thread Number: 29346
Hoover Convertible front seal attachment gasket |
Post# 327808   6/23/2015 at 11:07 (3,223 days old) by kloveland (Tulsa)   |   | |
I have a couple of attachment converters for newer front ‘seal’ attachments. The gasket/seal around the converter is worn. I noticed Hoover used a weather stripping type material and then later used a caulk type gasket. I’ve used weather stripping and it works for a while but then starts to fall off and wear out! Guess I could use super glue to glue it on. Anyway, is there a type of caulk that I could use that would be better? Or some type of gasket maker? That would be good for plastic? Does anyone know what hoover used to create the seal?
Post# 327811 , Reply# 1   6/23/2015 at 11:23 (3,223 days old) by HooverCelebrity (Germany)   |   | |
I would imagine that a generous bead of silicone would probably do the trick. |
Post# 327815 , Reply# 2   6/23/2015 at 13:45 (3,223 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 327822 , Reply# 3   6/23/2015 at 15:27 (3,223 days old) by Hooverboy81 (Myrtle Place)   |   | |
I've used this with success. Also works well for making a "permanent" motor gasket!
http://pages.ebay.com/link/QUESTIONMARKR... |
Post# 327834 , Reply# 4   6/23/2015 at 16:47 (3,223 days old) by kloveland (Tulsa)   |   | |
