Thread Number: 29237
Eureka Dial-A-Nap vs. ESP vs. Rugulator vs. The Boss 1934 vs. Retro Vac vs. Sanitaire SC888 |
Post# 326568   6/7/2015 at 22:01 (3,243 days old) by floor-a-matic (somewhere)   |   | |
Which one is the better vacuum for vacing deep down dirt? Which has more airflow/suction? I prefer to use disposable paper bag system & Vibra Groomer I or II roller on whichever machine I might buy |
Post# 326589 , Reply# 1   6/8/2015 at 09:03 (3,242 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 326621 , Reply# 3   6/8/2015 at 19:55 (3,242 days old) by eurekaprince (Montreal, Canada)   |   | |
Hi Erik,
You are kind of mixing apples and oranges here. Firstly, "Dial-a-Nap" and "Rugulator" are terms that just describe Eureka's 2 classic devices to raise or lower the front of the vacuum head. Neither one is better or worse when it comes to cleaning effectiveness. One uses a dial and the other uses a "slider" to adjust the height of the working end of the cleaner. Set either too low or too high and the vac won't clean well. Your other descriptions are just marketing names and really don't mean anything when comparing Eurekas. There are Bosses that clean better than ESP's and vice versa. Also, I really don't think that there is much of a difference in cleaning effectiveness between the three versions of Eureka Vibra-Groomer brushrolls: One, Two or Three clean equally well. The only thing that will differentiate the cleaning power of a group of classic "fan-first" Eureka uprights using F&G "bags in the back" is motor amperage. A 7amp motor will have more power than a 3amp motor. You can choose any of the various Eureka fan-first uprights, but I guarantee you the better cleaner will have the more powerful motor. |
Post# 326662 , Reply# 5   6/9/2015 at 18:00 (3,241 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 326677 , Reply# 6   6/10/2015 at 05:35 (3,241 days old) by pr-21 (Middletown, OH)   |   | |
I have a Eureka model 260 and had a Sanitaire Blue Line with the 7 amp motor. I agree with Hans. The Eureka 260 is by far the best. I even had a two speed 7 amp motor, considered a step down motor, from a new sc889, put in my 260. I also put the ST bag adapter fill tube on it as well. It has great filtration and is one of my best deep cleaner uprights I have. The brush roll never stalls, I did put a nos square end Vibra Groomer II in it as well, along with a new 30ft cord.
PR-21
Post# 326685 , Reply# 8   6/10/2015 at 11:05 (3,240 days old) by eurekaprince (Montreal, Canada)   |   | |
Aha. I see.
Indeed, the weight of the motor head does help keep all 4 upright wheels on the ground, and allows the cleaner to maintain the desired height level at which you set the Dial-A-Nap or the Rugulator. Our Vanguard Rugulator 2083 had a full metal base and metal hood and was an excellent cleaner with only a 3.5amp motor and VG One Brushroll. But it was heavy to lug down the stairs to the basement and back. At our vacation home, we had a cheaper Eureka 1976 Dial-A-Nap upright with a lightweight orange Lexan base and metal hood that was much lighter, but never made a nose-dive because the motor was only 3.5 amps. So, if you are going to go with a high-powered (7amps) fan-first, F&G bag Eureka or Sanitaire upright, you will be better off with one that has a solid metal base or at least a metal hood. The weight will work better with the stronger motor. |
