Thread Number: 29231
What bearings do your Modern Day vacuums use? Help |
Post# 326523   6/6/2015 at 22:58 (3,217 days old) by chicagomike (Plover, WI)   |   | |
Hi, I hope collectors of other brands of vacuums (besides kirby's) can tell me what bearing styles are used in your vacuums. I am specifically interested in the bearing identification number/style number (not a hoover part number but the actual style number of the bearing and bearing manufacturer). See photos as a reference.
The kirbys from 505 (1945) to present day use only 4 different bearings. One bearing is mounted in a hole on the front bearing plate which is then placed over the front of the armature shaft, and another bearing goes on the rear of the armature shaft. These 4 bearings are 1. 608 (rearing bearing from Classic Omega-Present) 2. 8007 (rear bearing from 505-Classic), 3. 8500 (front bearing from 505-Classic) 4. 6200 (front bearing from Classic Omega-Present) |
Post# 326597 , Reply# 1   6/8/2015 at 11:06 (3,216 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The 608 8 mm bearing is the most common bearing I have run into servicing vacuum motors. |
Post# 326643 , Reply# 2   6/9/2015 at 12:23 (3,215 days old) by chicagomike (Plover, WI)   |   | |
