Thread Number: 29230
Bearings styles/series vacs use? - Help |
Post# 326522   6/6/2015 at 22:56 (3,218 days old) by chicagomike (Plover, WI)   |   | |
Hi, I hope collectors of other brands of vacuums (besides kirby's) can tell me what bearing styles are used in your vacuums. I am specifically interested in the bearing identification number/style number (not a hoover part number but the actual style number of the bearing and bearing manufacturer). See photos as a reference.
The kirbys from 505 (1945) to present day use only 4 different bearings. One bearing is mounted in a hole on the front bearing plate which is then placed over the front of the armature shaft, and another bearing goes on the rear of the armature shaft. These 4 bearings are 1. 608 (rearing bearing from Classic Omega-Present) 2. 8007 (rear bearing from 505-Classic), 3. 8500 (front bearing from 505-Classic) 4. 6200 (front bearing from Classic Omega-Present) |
Post# 326541 , Reply# 1   6/7/2015 at 09:35 (3,217 days old) by BikerRay (Middle Earth)   |   | |
Electrolux Model XI used Norma C97 ( 627 ) for both front and rear bearings
Electrolux Model XII used Norma C97 for the rear and Norma XB110 for the front Electrolux Model XXX used 627 for the rear and 629 for the front bearings Electrolux 1205 used SKF R8 ( 608 ) for the front and a bronze sleeve for the rear bearing. Electrolux Epic 6000 used 608 for the front and rear bearings Hamilton Beach No. 14 upright used 87007 or ND 8008 for both front and back bearings The Kirby C used ND 8008 for both front and rear bearings. (ND being for New Departure) Rexair A, B & C used 88500 for the top and 88502 for the bottom bearing Rainbow D & D2 used 88502 for the top and 88011 for the bottom bearing Rainbow D3 used 6201 for both upper and lower bearing Rainbow D4 and D4C SE used 6201 for all three bearings |
