Thread Number: 29228
Tristar EXL |
Post# 326527 , Reply# 1   6/7/2015 at 05:37 (3,240 days old) by Blackheart (North Dakota)   |   | |
The EXL is either the best or the 2nd best Aerus made tristar out there. The EXl uses a dual stage motor with a tapered front fan and produces about 3x the airflow of the MG1 and MG2 which use the single stage VM3 motor. The new CS, which uses a brushless motor, is supposed to have about 42 cfm so it's very comparable to the EXl's flow.
Post# 326540 , Reply# 2   6/7/2015 at 09:32 (3,239 days old) by Kirbyduh (Kentucky )   |   | |
I have seen the motor upgrade kits to convert to the CS motor, and I think I may do that in the future. I really like brushless motors. I wonder why they used a motor in the MG vacuums that moved less air than the EXL? |
Post# 326542 , Reply# 3   6/7/2015 at 10:29 (3,239 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Post# 326548 , Reply# 4   6/7/2015 at 14:06 (3,239 days old) by Kirbyduh (Kentucky )   |   | |
That is very interesting. It's a shame that the VM3 motors were not as good. |
Post# 439451 , Reply# 5   3/6/2021 at 00:02 (1,141 days old) by ridgidwd0670 (se wood co ohio)   |   | |
Post# 439458 , Reply# 7   3/6/2021 at 10:34 (1,140 days old) by Lesinutah (Utah)   |   | |
People say I put tristar on a pedestal. The motor is a 2 speed very similar numbers to the compact one speed motor. The compact motor doesn't burn up as quick seal has 1 inch water lift higher and similar cfms.
The glasses worn by the praisers are putting this vacuumm on a pedestal. I get grilled for saying compact c9 and dxl are great and powerful. This is a good vacuum and I'm guessing it filters so well. If you put the but plug or filter on a compact the difference is a wash. It's great you toot your horn on this but cut down the c9-dxl compacts. It's funny diss on vacuums they don't like but toot the horn of vacuums they do like. Aerus made over priced average vacuums. The aerus electroluxes remind me of a long bus. The aerus tristars motors burn up very quickly. To the original poster I'm not trying to hijack this thread. You have a great vacuum and it preforms well. |
Post# 439459 , Reply# 8   3/6/2021 at 12:51 (1,140 days old) by Blackheart (North Dakota)   |   | |
Post# 439468 , Reply# 9   3/6/2021 at 20:30 (1,140 days old) by Lesinutah (Utah)   |   | |
Post# 439560 , Reply# 10   3/8/2021 at 19:26 (1,138 days old) by ridgidwd0670 (se wood co ohio)   |   | |
Post# 439567 , Reply# 11   3/8/2021 at 22:49 (1,138 days old) by Lesinutah (Utah)   |   | |
Post# 439677 , Reply# 12   3/12/2021 at 03:25 (1,135 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
8
Ok, that's it! Hold it right there. It's time to call you out, correct some of your mistakes in your post & put you & your arrogant, know-it-all attitude & opinions in your place!
"Aerus made over priced average vacuums. The aerus electroluxes remind me of a long bus." Oh really eh? Well, then I guess you had better say the same about your beloved Compact & TriStar vacuums, whether made by Interstate or Aerus Electrolux. For starters, the Aerus Electrolux canisters that use the Style C bag actually filter BETTER than the genuine OEM TriStar bags. The Aerus Home Solutions & aftermarket 4 ply bags based on their previous designs leave hardly ANY dust in the bag chamber, because they have layers to trap the dust & also help the vacuum to retain it's airflow LONGER than the TriStar & Compact canisters. The TriStar & Compact OEM bags are single ply paper bags with no microfiltration lining at all, & leak TONS of dust into the cloth bag which holds the paper bag in the cleaner. Even if you use the aftermarket microfiltration bags, they are slightly better, but some of the microfiltration layer gets blown off at the back of the bag, so dust leaks through that area. Yes, there are Vacuum America Clean HEPA Cloth TriStar bags which correct the issue of the dust leakage from the bags, but they are harder to find and obviously more expensive then the normal paper bags, even compared to buying generic single layer TriStar bags. Electrolux 4 ply bags are also cheaper to buy than the TriStar bags too, so there's less cost of ownership too. In addition, unlike what Compact & TriStar claim about their claners being "cyclonic", they are NOT. Sure the dirt falls at the front of the bag & not towards the back, but if you look where the end of the hose port is in the bag door, it's obvious why the dirt falls at the front of the bag! Furthermore, Miracle Mate, Vortech Force & Patriot all came out with tubes incorporated into their bag doors, redesigning the "cyclonic" action so that it works better. However, the Aerus Electrolux canisters ARE cyclonic. See the ribs inside the bag chamber? Go ahead & use your Electrolux to clean with, then open the bag door, hold the hole open, shine a flashlight into the bag, & what do you see? The dirt is on the side walls of the bag, not the back, & there is a clear path right in the middle of the bag for air to get through to the motor. Furthermore, on the earlier Electrolux 2100 canisters & the Electrolux Epic 6500SR & Aerus Legacy, they have the Automatic Control system which not only tells you when the bag is full, but unlike others, it can be customised to your cleaning needs & actually REALLY WORKS. Unlike most of these piston-style bag check indicators that only go off when the bag is so full & clogged it's doing hardly any cleaning at all. Furthermore, the Aerus Electrolux Epic 6500SR & Aerus Legacy have a headlight on their powerheads, & floating height adjustment in the back, so unlike the TriStar powerhead's fixed wheels, it won't dig in too deeeply into the carpet. However, you can fix the wheels on the Aerus Electrolux powerhead too if so desired. Also, the Legacy & Epic 6500SR wands are wider in diameter internally than the plastic TriStar wands, which means the vacuum is capable of moving more airflow thru the entire vacuum. And where do you think TriStar got their hose material, MiniStar small powerhead & cloth electrostatic exhaust afterfilter from? Aerus. You can say all you want about Aerus vacuums being overpriced....to some people they are when bought new. But so are the TriStar vacuums too. But the Aerus Electrolux canister vacuums are FAR FROM AVERAGE. And might I remind you, Electrolux actually invented the canister vacuum in 1924 in the first place! Your beloved TriStar & Compact vacuums would have never existed if Electrolux never invented the canister vacuum for them to copy decades later when the patents expired. "The aerus tristars motors burn up very quickly." Are you referring to the Electro Motor made motor originally installed in the EXL, or the Domel replacement motor that was the authorized warranty replacenent motor Aerus supplied after they sold off Electro Motor? Yes, the Domel double stage motors were short lived, because they were made in Slovenia & poor quality. The Electro Motor originally installed works excellent though and lasts about 20 years on average, same as the Ametek 116311 motor used in the TriStar CXL. And as for your statement to Rigidwd0670 that the stock Ametek 116311 motor used in the Compact & TriStar CXL would have mote power, waterlift & CFM, you would definitely be wrong on that! Those motors only pull 90" waterlift. The current double stage Electro Motor sold thru vac shops pulls 100" waterlift, as does the Ametek 115923 that can fit all these vacuums. In addition, Numatic has a Ametek double stage motor that pulls 110" waterlift, and there is a double stage Electro Motor from Centralvacuummotor.com available that pulls 117" waterlift! Now, would you like to be foolish enough to try to defend your statement? Get your head out of your ass & start being a bit more polite & not so insulting in your postings, please and thanks. I for one am getting sick of seeing your superior attitude, & insulting others with opinions different than yours. Just because you don't agree with someone's opinion is NO EXCUSE to be rude in a reply to a fellow member! I DARE YOU to reply to this, because you literally just got your ass handed to you! Rob |
Post# 447695 , Reply# 14   11/7/2021 at 01:41 (895 days old) by SudburyMan (Sudbury)   |   | |
This sure has provided me a lot of insight as a collector of Electrolux and having thought about scooping up a pending listing of a Tristar. My hat is off to you Sir. |
Post# 447936 , Reply# 15   11/17/2021 at 13:17 (884 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
I have to agree with Kirbylux77' on it the bags for tristar cost more and the lining do wear and tear after time NOT and issue with the trusted lux desing i have to agree on that yes .Owning both a Compact C8 C9 CXL and a lux zb89 the lux never tore a hole in her bag or lining never .
So if you do go for a cxl c2 or new a101 mg2 mg3 cs ect tristar comapct be prepare to keep an eye on your bags more ofthen than her Electrolux sister .But with that in mind you will havea wonderfull fun machine to play and clean with good luck to ya .
and lets try to keep it clean in post i am guilty of blowing up but i came back again i agree Kirbylux77'.But i will say we all here to tlak vacuum bag filter ect so lets apreciate the fact that some love other machine than us i dont like bagless yet i usea tristar lol go figure |
Post# 447956 , Reply# 16   11/18/2021 at 00:39 (884 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Thanks for your kind words, Antoine. One other nice thing about changing a Electrolux bag is it's so simple, easy and clean. With a TriStar, being a open top bag design, the dirt is exposed and usually a bit around the rim too. And unlike a Electrolux bag that you just drop in, you have to mess with putting the TriStar paper bag into the cloth liner bag, then put both in the vacuum. The Electrolux bag design is such a nice, pleasant, easy to use design, no wonder the same bag has been used continuously with hardly any changes since 1952.
One word of caution with the Electrolux bags though - one thing I have noticed that is a design flaw, and has since been rectified by Aerus, is the blue sealing strip that holds the top and bottom of the bag together at the back. On both genuine and generic bags, by Envirocare and DVC, what I have noticed is you will get the odd bag that starts to split right at the sealing strip and leak dirt. Enough that I would suggest anyone using those bags put the paper bag in a HEPA Cloth bag as a liner when putting in the vacuum. However, there are certain brands of bags you can get for Electrolux vacuums where the paper bag is made the conventional way by folding over the bag material and gluing in place at the back. The blue Aerus Home Solutions bags, Arm & Hammer bags, Clean Fairy brand Electrolux bags sold on Amazon, and one of Hibbert International's brands of bags (vac shop distributor in Canada) are brands of Electrolux bags being made this way. These bags will NOT split in the back and cause any issues. Or of course you can just use HEPA Cloth Electrolux bags :). Jimmy - Good to know what the Aerus Electrolux dealers are using to demonstrate Electrolux's cyclonic bag action. That actually makes sense....if the customer likes the scent of the Clean Sweep chips, that's one more thing they can sell the customer. I actually just recently found a dealer in Brampton, Ontario that had the Style C and Style R cloth demo bags in stock, so I ordered 2 of each for my Guardian and Epic 6500. Nice to have for messy jobs you don't want to waste a bag on :). Rob |
Post# 463200 , Reply# 18   5/17/2023 at 14:23 (338 days old) by Blackheart (North Dakota)   |   | |
My my such an old thread and man was I clueless at the time.
The CS does not use a brushless motor it's a brushed motor made by Johnson Electric there were rumors that it would be brushless and I think it having the brushes near the front of the fan case only fueled this rumor. Also my assumption of 42 cfm is far off. The methods I were utilizing at the time was based off bad assumptions created by a poor understanding of the airwatts formula. Here you can see how the Tristar MG2 does. and I also have measured a CS but unfortunately I have little data on the EXL other than knowing it does indeed have more flow than the MG2 not 3x as much granted but more than it. Now I don't know if the EXL surpasses the CS or not. Do keep in mind the longer your hose is the more airflow you'll lose. The measurements I had gotten for the CS Were: Hose: 90.41 CFM ~67" Wand:85.29 CFM 63" Head: 68.33 CFM ~16"
Post# 463204 , Reply# 19   5/17/2023 at 20:38 (338 days old) by Lesinutah (Utah)   |   | |
