Thread Number: 29052
Photo Request Kirby G3/G4 cord mounting. |
Post# 324732 , Reply# 1   5/12/2015 at 20:49 (3,268 days old) by BikerRay (Middle Earth)   |   | |
The original or the replacement scuff plate?
The original had a trianglar piece that went over the cord to the side of the scuff plate, then screwed to the top of the scuff plate. This one is no longer available. The replacement scuff plate has an opening on the side for the anchor on the cord to fit in under the scuff plate. The cord anchor goes in first, then the scuff plate snaps down on top of the anchor and then the screw goes thru the scuff plate, anchor and into the upper shell housing. |
Post# 324734 , Reply# 2   5/12/2015 at 21:16 (3,268 days old) by fordiesel69 (USA)   |   | |
The original scuff plate and cord. Someone took it all aprt and now I am having trouble getting it back on. When I install the cord, the vacuume will not go into reverse. |
Post# 324737 , Reply# 3   5/12/2015 at 21:55 (3,268 days old) by BikerRay (Middle Earth)   |   | |
Since my G4 has been converted to the newer style cord, here's how the cord would go in the older style setup. In this picture I used a gray cord for contrast. The older scuff plate would go on the upper shell first. The cord gets zip tied to the trianglar piece and the trianglar piece has a round raised section on the bottom side that fits into the hole on the scuff plate. Then the screw goes into the trianglar piece holding it to the upper shell.
If you can't get the vacuum to go in reverse 1. is the screw too long and the slide bracket hitting on the screw? 2. is the triangular piece seated in the hole of the scuff plate or is it sticking up and the handle spring assembly is hitting on the front edge of it?
Post# 324741 , Reply# 4   5/12/2015 at 22:20 (3,268 days old) by BikerRay (Middle Earth)   |   | |
Post# 324772 , Reply# 5   5/13/2015 at 14:19 (3,268 days old) by chicagomike (Plover, WI)   |   | |
Post# 324805 , Reply# 7   5/13/2015 at 20:20 (3,267 days old) by BikerRay (Middle Earth)   |   | |
Post# 324813 , Reply# 8   5/13/2015 at 21:37 (3,267 days old) by fordiesel69 (USA)   |   | |
My collection stopped at heritage II. Im quite confused....... |
Post# 325096 , Reply# 9   5/18/2015 at 05:56 (3,263 days old) by fordiesel69 (USA)   |   | |
So in conclusion, on my g4, is it as simple as buying the updated scuff plate and screw it together like pictured on that G3? |
Post# 325126 , Reply# 10   5/18/2015 at 21:26 (3,262 days old) by chicagomike (Plover, WI)   |   | |
g4 cord mount
Post# 325220 , Reply# 11   5/19/2015 at 18:38 (3,261 days old) by BikerRay (Middle Earth)   |   | |
OK, here's a picture of the cord from a G5 (so pay no attention to the color) with the in line clip. If this is the cord you have then YES you need the updated scuff plate.
