Thread Number: 28896
Kirby G5 Transmission Question |
Post# 323013   4/22/2015 at 22:44 (3,290 days old) by DaftBronyG5 (Bellmawr, NJ )   |   | |
Well, I was finally able to get one of my most wanted Kirby models; the G5! Got it for $40 off Craislist. The machine's a little grungy but nothing a good buffing won't fix. It's actually one of the more cleaner G series I've ever picked up. However, I am curious as to something I found with the transmission. When the machine is off and you push it forward in netural, it makes a soft clicking noise. Nothing too loud or intense. So, after a little research I took the machine apart to check the amature where the gears engage and they seem to be at an appropriate spacing. Nothing touching or rubbing up against anything. Even flipped the pedals a few times and it seems to engage/disengage just fine. So I put it back together (after blowing out all of the dust) and it seems to operate fine in use. But it's just bothering me for some reason. It only happens when pushing it forward in netural, which perplexes me even more. Pull it backwards and it's quiet as a church mouse. Anyone have any ideas?
Post# 323059 , Reply# 2   4/23/2015 at 13:50 (3,290 days old) by human (Pines of Carolina)   |   | |
Post# 323066 , Reply# 3   4/23/2015 at 14:48 (3,290 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 323080 , Reply# 4   4/23/2015 at 17:16 (3,290 days old) by human (Pines of Carolina)   |   | |
I'm not sure. the bracket cam assembly is the metal plate that goes between the n/d pedal and the gears that engage and disengage the transmission. For reference, I've included the photo from the eBay auction where I bought mine. The cam may be on the inside end of the N/D pedal's shaft. It engages with the little arm at the top of the photo to move it on its pivot so the other end of the arm engages or disengages the gears.
Post# 323084 , Reply# 5   4/23/2015 at 18:08 (3,290 days old) by sptyks (Skowhegan, Maine)   |   | |
