Thread Number: 28891
Filter Queen Brush Roller |
Post# 323003 , Reply# 1   4/22/2015 at 19:36 (3,290 days old) by pr-21 (Middletown, OH)   |   | |
Your brush roll should be able to be adjusted one time. When you remove the rug plate, notice the rubber end caps. Rotate the end caps 180 degrees and it should raise your brush roll so that you get more bristles sticking out when you replace the rug plate. If it has already been adjusted once, you will need a new brush roll. They do make aftermarket brush rolls to fit or you can stick with the genuine.
PR-21 Bud |
