Thread Number: 28876
Dustbuster may not work |
Post# 322686 , Reply# 1   4/20/2015 at 16:32 (3,265 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 322696 , Reply# 2   4/20/2015 at 17:00 (3,265 days old) by Svacuums (IN, usa)   |   | |
My grandpa had an old one when I was a kid and I tried to turn it on when it was on the charger and it never worked again. I'm sure you could take it to a batteries plus or something and they will fix it. |
Post# 322697 , Reply# 3   4/20/2015 at 17:08 (3,265 days old) by human (Pines of Carolina)   |   | |
I hate to say 'I told you so', but nickel cadmium (NiCd) batteries just don't last 30 years, even if they've been in storage. I don't think the seller intentionally ripped you off; it's just the nature of the beast. The battery's internal components deteriorate over time. You're going to have to take the unit apart, remove the battery pack and see if you can find a compatible replacement. If possible, get a nickel metal hydride (NiMH) battery instead of NiCd. They are overall much superior, hold a better charge and they don't have the 'memory effect' that plagues nickel cadmium batteries.
Post# 322698 , Reply# 4   4/20/2015 at 17:37 (3,265 days old) by vacman1961 (North Babylon, New York)   |   | |
You didn't get scammed, you bought a vintage Dust Buster that is battery powered. Rechargeable batteries do not last that long, whether they are used or not the most they will last is 5 years. Do your research, you might be able to buy a new battery pack for it. Good Luck. |
Post# 322704 , Reply# 6   4/20/2015 at 19:57 (3,265 days old) by human (Pines of Carolina)   |   | |
Hey, I'm glad--if a little surprised--it's working that well with the old battery. NiCd batteries are bad for developing a 'memory' for the amount of use between charges. Be sure to charge it completely each time and DON'T put it back on the charger until it is COMPLETELY discharged. This will ensure maximum battery life between charges.
Post# 322706 , Reply# 7   4/20/2015 at 20:14 (3,265 days old) by human (Pines of Carolina)   |   | |
Oh, about the Sears brand. I'm 99 percent certain it's a re-branded Black & Decker. Sears--and other retailers--do this all the time. I have a Sears LXI TV set that's about 20 years old and still works great. It's a re-branded GE. When I was growing up, we had a TruTone TV from Western Auto that was also a re-branded GE. The Lexmark printer company used to make Dell branded printers. They even used Dell branded ink cartridges. The tops were shaped differently so the Dell and Lexmark branded cartridges weren't physically compatible with each other's printers, even though they came off the same production lines and were otherwise identical. I could go on and on, but you get the idea.
Post# 322718 , Reply# 8   4/20/2015 at 21:58 (3,264 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Edgar,
It is a re-badged Black & Decker Dustbuster in his case. In addition, Sears also marketed the Cordless Vac Plus which was a re-badged Black & Duster model 9333 Dustbuster Plus, which had the same coffee brown color for the main unit and charger base. That one employed a 5-cell (6 volt) battery for longer running time. ~Ben |
Post# 322865 , Reply# 9   4/21/2015 at 21:25 (3,263 days old) by Vintagevaclover (Athens, GA)   |   | |
I also have a vintage original DustBuster with the box, wall charger, manual & everything. It works like I just bought it. My roommate found it at the thrift shop and thought I might like it. I would try letting it charge overnight and see if that works, if not, you may have gotten scammed. I too love most vintage vacuums, mostly uprights though.
