Thread Number: 28661
Kirby DS 50 Fan Case Housing Cleaning |
Post# 319759   3/30/2015 at 22:40 (3,312 days old) by Paul (USA)   |   | |
There is something that looks like adhesive around the opening of my DS50's fan case housing. What would you recommend to remove it without harming the surface? |
Post# 319762 , Reply# 1   3/30/2015 at 23:19 (3,312 days old) by Firebirdman55 (Owensboro Kentucky)   |   | |
Post# 319792 , Reply# 2   3/31/2015 at 10:29 (3,312 days old) by sptyks (Skowhegan, Maine)   |   | |
Do you mean the opening where the shaft protrudes the fancase or where the front of the fancase attaches to the main part of the motor unit? If it is the latter, you can remove the old sealant with a knife or razor blade. Make sure to reapply a thin layer of silicone sealant when you re-attach the front of the fancase.
There should be no sealant around the air intake opening. |
Post# 319818 , Reply# 3   3/31/2015 at 14:58 (3,312 days old) by Bikerray (Middle Earth)   |   | |
Post# 320059 , Reply# 5   4/2/2015 at 11:05 (3,310 days old) by chicagomike (Plover, WI)   |   | |
Remove the old gasket, scrape off all the old gasket the best you can, use acetone or MEK to remove the adhesive you cannot scrape off, then buy a new o-ring gasket from a local kirby dealer and re-glue the new one on using 3M 847 Rubber and Gasket Adhesive... However it is likely cheaper to have a local shop install it for you as the adhesive is $20-30 for a tube (which you will likely never use all of the adhesive from the tube unless you are restoring many machines).
Post# 320060 , Reply# 6   4/2/2015 at 11:07 (3,310 days old) by chicagomike (Plover, WI)   |   | |
P.S., if you removed the fan case housing, use a scraper to remove all the old adhesive from the fan case housing and from the motor housing (so both mating surfaces will be clean and both surfaces will mate together flat) then apply silicone to one surface, let it sit 10 minutes, then screw both mating parts back together.
