Thread Number: 28477  /  Tag: Brand New Vacuum Cleaners
Hoover Zen Whisper Cyclonic SH40080 problem
Post# 318133   3/13/2015 at 00:28 (3,331 days old) by floor-a-matic (somewhere)
My Hoover Zen canister won't power on; what could be the problem with it? Filters are clean, no clogs inside hose & wand
Post# 318146 , Reply# 1   3/13/2015 at 11:08 (3,331 days old) by dysonman1 (the county)
Does the power nozzle run, but not the canister motor? If the power nozzle doesn't run either, it's probably in the cord or winder mechanism. Were you using the machine when it shut off? The thermostat will reset once the machine cools to room temperature. If power head runs, but not motor of canister, it's possible one of the carbon brushes is stuck in the holder.
Post# 318150 , Reply# 2   3/13/2015 at 12:01 (3,331 days old) by floor-a-matic (somewhere)
Neither the vacuum or PN turned on; not sure if the switch went bad
Post# 318775 , Reply# 3   3/19/2015 at 13:00 (3,325 days old) by floor-a-matic (somewhere)
Update
The PN powered on (when I connected it directly to wall outlet) but I dont know if the Thermal Reset went bad? Where can I get a new Thermal Reset "switch" or Power button?
