Thread Number: 28291
Kirby Sanitronic VII |
Post# 316100   2/19/2015 at 15:51 (3,324 days old) by fantomfan (Rochester, New York)   |   | |
My Uncle gave me a Kirby Sanitronic 7 and a Heritage 2 Turbo. They both work well, but the Sanitronic had the light bulb housing cut off, and is missing the nozzle. It's too bad, because it runs beautifully and has the ORIGINAL bag. I was wondering, if a Sanitronic 50 nozzle would fit on this? I saw a couple on ebay. The Heritage is perfect and just needed a new cord. Thank You! -Mitchell
Post# 316103 , Reply# 1   2/19/2015 at 16:37 (3,324 days old) by Bikerray (Middle Earth)   |   | |
A Dual 50 nozzle will NOT fit a Sanitronic VII. The 50 safety switch has 2 buttons where as the Sanitronic VII safety switch only has 1 button. The activation tab on the back of the nozzle is in a different place, the VII would be centered and the Dual 50 would be either side of center.
If the light hood was cut off is there still the hinge? If so you can drive the pin out and replace the hood. |
Post# 316106 , Reply# 2   2/19/2015 at 16:57 (3,324 days old) by fantomfan (Rochester, New York)   |   | |
Post# 316107 , Reply# 3   2/19/2015 at 17:08 (3,324 days old) by Bikerray (Middle Earth)   |   | |
The good news is that the Headlight Socket & Wire part #108268 is still available from Kirby. They used that part from the 516 thru the Classic.
Next question, did they cut the wires? Because the wires run thru a hole in the top of the motor housing and come out the side going to the switch. If the wires are still there and they were cut you might have a wire touching another wire or shorting to the case. |
Post# 316152 , Reply# 4   2/20/2015 at 06:41 (3,324 days old) by fantomfan (Rochester, New York)   |   | |
Post# 316156 , Reply# 5   2/20/2015 at 06:53 (3,324 days old) by fantomfan (Rochester, New York)   |   | |
Post# 316159 , Reply# 6   2/20/2015 at 08:24 (3,324 days old) by Bikerray (Middle Earth)   |   | |
Post# 316184 , Reply# 7   2/20/2015 at 11:15 (3,323 days old) by fantomfan (Rochester, New York)   |   | |
Post# 316209 , Reply# 8   2/20/2015 at 14:27 (3,323 days old) by fantomfan (Rochester, New York)   |   | |
Post# 316288 , Reply# 9   2/21/2015 at 10:29 (3,322 days old) by FantomFan (Rochester, New York)   |   | |
Post# 316319 , Reply# 10   2/21/2015 at 13:34 (3,322 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 316351 , Reply# 11   2/21/2015 at 17:04 (3,322 days old) by FantomFan (Rochester, New York)   |   | |
