Thread Number: 28251
How to Set the Height on My New Sanitaire |
Post# 315691 , Reply# 1   2/16/2015 at 19:48 (3,349 days old) by Kirbyloverdan (Egg Harbor Twp . NJ aka HOOVERLOVERDAN ❤️)   |   | |
Post# 315695 , Reply# 3   2/16/2015 at 20:13 (3,349 days old) by Kirbyloverdan (Egg Harbor Twp . NJ aka HOOVERLOVERDAN ❤️)   |   | |
Post# 315709 , Reply# 4   2/16/2015 at 21:25 (3,349 days old) by eurekaprince (Montreal, Canada)   |   | |
When I had a Dial-a-Nap Eureka, I always started at a higher setting when using a new empty dustbag which resulted in very high suction. Later on, as the suction reduced, I would lower the nozzle height to maintain good deep cleaning.
Your Sanitaire probably has a very powerful 7amp motor, so I'd keep the nozzle at a height where you hear the low vibration of the brush at the same time as allowing good air flow with no "suction lock" on the carpet. It will save you from constantly installing new belts, and it will allow the cleaner to do a better job of edge cleaning. Too low a setting will hurt cleaning effectiveness, not help it. As long as you hear the brushroll vibrating the carpet, you are down low enough. |
Post# 315730 , Reply# 6   2/17/2015 at 06:12 (3,349 days old) by Miskini (Northville, Michigan )   |   | |
Post# 315739 , Reply# 7   2/17/2015 at 07:16 (3,348 days old) by eurekaprince (Montreal, Canada)   |   | |
