Thread Number: 28183
Epic 6500 Broken Switch Assebly |
Post# 315057 , Reply# 1   2/9/2015 at 21:09 (3,357 days old) by DJub85 (Virginia)   |   | |
New question. I found the "switch housing" for sale online, but how in the heck do you get the old diaphragm and switch/wires off of the old housing?
Sheesh. I'd have preferred putting a motor in this thing.
Post# 315061 , Reply# 2   2/9/2015 at 22:16 (3,357 days old) by Bikerray (Middle Earth)   |   | |
That's only part of the switch assy. The switches are mounted in a clear plastic piece that will snap into the bottom of that housing. Then from the top side you will have the on/off push button riding in the two posts sticking up. Underneath the button there will be a clear plastic rocker that snaps into that base, there will also be a spring that hooks into the edge of the switch base and also the edge of the rocker. The spring will have a clear rubber piece going thru the center of the spring. Normally when you get the switch assy from Electrolux it will have the vacuum diaphram mounted in the switch assy base.
The switch in the pictures came out of an LE so it doesn't have the vacuum diaphram shut off. Hope this helps |
Post# 315102 , Reply# 4   2/10/2015 at 11:29 (3,356 days old) by Collector2 (Moose Jaw, Sk)   |   | |
