Thread Number: 28144
Electrolux XXX motor |
Post# 314661 , Reply# 2   2/5/2015 at 14:55 (3,365 days old) by Bikerray (Middle Earth)   |   | |
The G motor should fit into the model XXX since the mountings are basically the same.
As to wiring, the model XXX had the 2 motor wires and 2 wires that came from the capacitor, I don't remember if the G used a capacitor or not (I know the F did). If not then it's only 2 wires to worry about. The model XII uses a whole different mounting system then the XXX series and up. So no that would not work. The 12 has 3 small screws the go thru the bakelite mounting ring into the outer housing of the 12. You unscrew those and then twist the motor slightly then it will slide out of the outer housing. The motor itself is suspended by springs inside the ring. |
Post# 314663 , Reply# 3   2/5/2015 at 15:03 (3,365 days old) by Bikerray (Middle Earth)   |   | |
Post# 314783 , Reply# 5   2/6/2015 at 17:29 (3,364 days old) by Kirbyduh (Kentucky )   |   | |
Thanks for the help and advice. I am going to try to decide which route to go. I appreciate the help. |
Post# 319214 , Reply# 6   3/24/2015 at 09:06 (3,318 days old) by s31463221 (Frenchburg, KY)   |   | |
Post# 319669 , Reply# 7   3/29/2015 at 18:20 (3,313 days old) by Dennis (California)   |   | |
Just bought this from a lady getting divorced. Starts and stops intermittently. Any ideas? If I remove the hose its runs ok. Where can I get a pictorial of how to disassemble? Dennis CLICK HERE TO GO TO Dennis's LINK |
Post# 319679 , Reply# 8   3/29/2015 at 21:13 (3,313 days old) by Bikerray (Middle Earth)   |   | |
Post# 376924 , Reply# 9   8/16/2017 at 12:57 (2,442 days old) by db4c0574 (westchester, ny )   |   | |
revive, any other motors available from electrolux to fit the model 30, where could someone locate this elusive adapter nodule. |
