Thread Number: 27853
kenmore intuition dust problem |
Post# 311169 , Reply# 1   1/7/2015 at 13:22 (3,395 days old) by mark40511 (Lexington, KY)   |   | |
I didn't have the intuition canister - but the Progressive. If it's the same connection hose that connects to the canister as the progressive, honestly - I don't think it's the bags, I think it's the way the hose connects to the thing you slide the bag onto....I don't think it's tight enough.....
My Epic 6500 uses C bags that feel so much cheaper than the Kenmore bags - but it has a good seal and there is no dust in the bin area around the bag at all..I loved my Kenmore canister but hated the big getting dust in it like that.......Perhaps someone knows of a remedy - wish I did. |
Post# 311171 , Reply# 3   1/7/2015 at 13:43 (3,395 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
About dust leaking into your Kenmore....I have a little tip for you. The Kenmore & Panasonic canisters have a slight flaw with their bag holders - it's not unusual to see a bag slip out of it's holder once in a while, & for dust & dirt to escape getting into the bag & make the bag compartment dirty. I have noticed since the late 1990's, since Kenmore started putting HEPA filters on their canister vacuums, that they also started putting a rubber seal on the inside of the bag holder, where the cardboard bag collar mates up. I have found this to be an issue with causing the bag collar to slip up & dust to escape. My older Kenmore Whispertones back from the 80's & 90's didn't have this rubber seal & didn't have this problem. I would suggest try removing the seal when you take the bag out & replace it before installing the new bag. The bag collar will fit a little bit tighter in the holder, but that's what you would want anyways.
Rob |
Post# 311195 , Reply# 4   1/7/2015 at 17:11 (3,395 days old) by mark40511 (Lexington, KY)   |   | |
I forgot to mention this! Get this.....this happened 2 times to me on my Kenmore Progressive...I'm vacuuming for God knows how long and when I went to check the bag, it was almost all the way off and I basically had been vacuuming without a freaking bag. I was so mad and puzzled because I always put the bags on very carefully making sure they are on good, so I have no clue how that happened, but it happened twice and it was a mess. Thank God for the motor protection filter. After two times, I now tape the bag on the collar to make sure it doesn't slip off. The PN stopped working a long time ago so I use it in my laundry room the vacuum lint off the dryer lint screen and keep the laundry area clean.......So yea- there is a flaw in that design, that's for sure........
and I could be wrong, but I think this design has been on Kenmore/Panosonic canisters for a LONG time..... |
Post# 311203 , Reply# 6   1/7/2015 at 18:25 (3,395 days old) by suckolux (Yuba City, CA)   |   | |
Post# 311324 , Reply# 7   1/8/2015 at 18:51 (3,394 days old) by fan-of-fans (USA)   |   | |
I have this problem on my Kenmore Progressive as well (current generation) model. I am not using the Q HEPA cloth bags that it comes with, but I use the C Allergen bags. Not sure if that's my issue or not, but whenever I change the bag, I vacuum off the motor filter and clean the bag compartment. The fan behind the filter doesn't seem dusty, so I think the filter catches any dust that leaks.
This bag mount and bag have been around since 1984 or so, I can't remember if the older ones had a rubber seal on the mount, but it seemed like they did. Mine has a black foam donut on it. I have not had any bags slip off the mount though. |
Post# 311330 , Reply# 8   1/8/2015 at 21:11 (3,394 days old) by suckolux (Yuba City, CA)   |   | |
