Thread Number: 27395
Kirby Experts I Need Help |
Post# 307065 , Reply# 1   11/22/2014 at 14:18 (3,436 days old) by Kirbyduh (Kentucky )   |   | |
I have the same issue with my Heritage IIs. It got to the point where I just stopped using them. I agree- any insight on this issue would be great! |
Post# 307068 , Reply# 2   11/22/2014 at 15:13 (3,435 days old) by adambomb (Undisclosed )   |   | |
Use only genuine Kirby parts. Generic parts aren't of the same quality as the genuine parts. |
Post# 307069 , Reply# 3   11/22/2014 at 15:17 (3,435 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Jim,
I haven't had that problem on any of my two Kirbys - with the replacement brush rolls. But I will refer you to this section of the Heritage II service manual for your trouble. ~Ben
Post# 307083 , Reply# 4   11/22/2014 at 16:57 (3,435 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 307087 , Reply# 5   11/22/2014 at 17:45 (3,435 days old) by kirbykid63 (Wilmington Delaware)   |   | |
The tabs that hold the plastic brush ends are bent causing play that makes a rattle sound you need to ben the tabs inward to stop the play and the problem should go away. Rich new2youvacuums |
Post# 307097 , Reply# 6   11/22/2014 at 19:25 (3,435 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Post# 307131 , Reply# 7   11/23/2014 at 10:09 (3,435 days old) by ultralux88 (Denver, Colorado)   |   | |
I'm going to second the last 2 posts, make sure the screw adjustments on the ends of the brush are set correctly and evenly, and also bend the tabs that hold the sides of the brush ends in a bit, over time they can bend out and not hold it as tight as it is supposed to, bend them in a bit to get a good snug fit.
Post# 307155 , Reply# 9   11/23/2014 at 13:16 (3,435 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 307287 , Reply# 10   11/24/2014 at 23:26 (3,433 days old) by suckolux (Yuba City, CA)   |   | |
