Thread Number: 27261
Electrolux new motor |
Post# 305542   11/9/2014 at 23:29 (3,454 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 305710 , Reply# 1   11/10/2014 at 21:53 (3,453 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 307112 , Reply# 2   11/22/2014 at 23:32 (3,441 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 307117 , Reply# 3   11/23/2014 at 03:48 (3,441 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Post# 307136 , Reply# 4   11/23/2014 at 10:44 (3,441 days old) by Elux89 ()   |   | |
Find an Electrolux AP series canister, the motor will fit in no problem. If you opt for the ap 280, you will have to bypass the two speed setting. |
Post# 307208 , Reply# 5   11/24/2014 at 00:18 (3,440 days old) by compactc9guy (Bathurst NB)   |   | |
Thank you Kirbylux77 and Elux89,
I looked on ebay for a new motor and ive seen a few Amteck motor and though it would do a great job , altho i would need a new seal and around my town there isn't a lot of vacuum shop so im not to sure on what to do.If i do find an electrolux ap series motor i will install it thanks for the reply and have a wonderfull day |
Post# 307211 , Reply# 6   11/24/2014 at 00:40 (3,440 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Antoine, if you install a Electrolux AP Series motor, that would be a good option. If you do this, make sure you order a new set of carbon brushes for the motor & install them prior to installing the motor in your 86. However, if I had to choose between investing in a used AP series motor & a new Ametek motor, I would choose the Ametek motor. Why? Because the AP series motor could be anywhere between 31 & 41 years old. Just better not to take a chance on a motor that could be near the end of it's life.
If you do decide to consult a local shop & have a Ametek motor installed, a word of advice: Make sure the new motor draws less than 8 amps of power. This is CRUCIAL & very important! Our local vac shop, years ago, told me a horror story of how he installed a Domel 12 amp motor in a 89, & he wound up frying the customer's wiring & switch. Unfortunately, 8 amps is all the 80 series canister's power switch can handle. Also, if the shop can order the motor mount separately, ask them to install a Filter Queen single speed motor used in the Canadian Model 700....it only draws 6 amps of power & pulls 80" waterlift, same waterlift your 86 motor produces right now. If you want something with more power, a Ametek 116311 7.5 amp TriStar single speed motor can also work too....I have used it in the past with great results....and it pulls 90" waterlift, so about the same a new Aerus canister today produces. Good luck repairing your Electrolux 86.... Rob |
Post# 307274 , Reply# 7   11/24/2014 at 20:09 (3,439 days old) by compactc9guy (Bathurst NB)   |   | |
Thank you very much ROB,
I was thinking of installing a new tristar motor but , i would need some kind of mounting bracket or pl;ate not sure where iwould get that ill keep looking and ill let you know if i have question ill post them on here.Thank you for advising me on the voltage and amp my 86 power switch can handle i had no idea . |
Post# 307285 , Reply# 8   11/24/2014 at 23:10 (3,439 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Antoine, I was able to find the motor mounting plate for you. I will link it below for you. It is available thru Tip Top Parts, so as long as you can find a local vac shop that deals with that distribution company, you are all set. When you place the order with your local shop, make sure that they include the foam rubber seal as well. Now, when you install the motor, put the motor in thru the bag compartment, & make sure the foam rubber seal is DIRECTLY BEHIND THE MOTOR'S FAN HOUSING. You want it on the bag compartment side. Then, your motor mounting plate attaches to the holes on the motor to mount it, & you mount the motor mounting plate to the vacuum itself on the motor compartment side.
There is also a Ametek motor that is available with this bracket, & it is designed to fit the AP100 to 2100. It would work in this situation, but problem is although they say on the website it has the same waterlift as a TriStar motor, they don't specify the amps, so check that out before ordering it. Rob tiptopparts.ca/P-EL5920/Mounting-... tiptopparts.ca/P-EL5802/Motor-Ele... And here is the Ametek Electrolux AP Series motor from JohnnyVac www.johnnyvac.com/index.phpQUESTI... |
Post# 307324 , Reply# 9   11/25/2014 at 21:05 (3,438 days old) by compactc9guy (Bathurst NB)   |   | |
Thank you so much for all the information , i will check that out . I have been searching for a couple weeks now for the motor seal and new motor , you mention it was an amteck motor that would run perfectly and have lots of suction . Thank you so much . Now i guess ill have to install the motor my self there not really a vac shop around my town there is a place that sells parts for a central vac ill have to check if they install and repair canister vacuum as well .
Post# 314271 , Reply# 10   2/2/2015 at 23:34 (3,369 days old) by compactc9guy (Bathurst NB)   |   | |
hello every one i definitely need a new motor the wires are shot, brittle to the touch the coil looks used yup time for a replacement i found the gasket now i can get a new motor and get her going again no chance of getting the old one going again now , also the fan was just plain dusty no breathing right bad wires recepy for disaster if you ask me so new motor more $ into it but she will be a nice vacuum once i get her going again im a fan of vintage lux so yes ill fix her up .Hate seeing old vacs in the land filled when all it needed was a little love .
