Thread Number: 27260
Homemade vacuum attachments |
Post# 305533 , Reply# 1   11/9/2014 at 22:25 (3,454 days old) by RainbowD4C (Saint Joseph, Michigan )   |   | |
Used to use the empty cardboard rolls of wrapping paper as extra wands for extra reach. Years ago I had indoor outdoor carpet in the kitchen of my one apartment and it was to thin that the power vac for my Rainbow didn't pick up that well so I bought a extra floor brush and took the brush itself off and used that for cleaning low low pile carpet or the rugs in the bathroom.
Post# 305556 , Reply# 2   11/10/2014 at 00:18 (3,454 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 305660 , Reply# 3   11/10/2014 at 16:46 (3,453 days old) by DaveTranter (Central England, U.K.)   |   | |
I recently made one of these, to keep scrap metal separate from workshop dirt, and help keep metal particles off the felt filter of my Bosch. Yes, it works very well. A photograph will be appended as soon as I next go to the workshop. All best Dave T |
Post# 306865 , Reply# 4   11/20/2014 at 17:52 (3,443 days old) by DaveTranter (Central England, U.K.)   |   | |
I have no idea what machine the smaller hose is from.... It was just one I had lying around. Simple device, crude, but effective. The area airflow inside the canister is low enough that even very fine metal particles settle out. All best Dave T |
Post# 306951 , Reply# 5   11/21/2014 at 16:03 (3,442 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
I bought a battery operated LED light torch a couple of days ago and it has a handy hanger on it. Fits the front of the Cordless Air quite perfectly and very bright ! Not quite a home made tool but one that is effective!
Post# 306967 , Reply# 6   11/21/2014 at 17:51 (3,442 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 306980 , Reply# 7   11/21/2014 at 18:35 (3,442 days old) by Blackheart (North Dakota)   |   | |
Way back when i had a Black and Decker canister, which had a "reversed" wand like old hoovers or filterqueens. I made an upholstery tool out of soda cans i used one to make a neck and attached it to a partially flattened base with a hole cut in it, i only tried it out once or twice before i threw it away.
And about ...6 years ago i made a separator for a shop vac i had purchased. the plan was to use it like a central vacuum. I took a 5 gallon bucket and i think a 6 qt funnel. Initially i set it up like a normal cyclone (narrow end at the bottom) but found that lighter weight debris would just spin around the top of it, never depositing into the bucket. So i inverted the funnel and aimed the inlet slightly downwards, connected the vac to the separator with 2" pvc pipe to try to have as smooth an air path as possible. It seemed to work much better in this configuration. I also made a hose for that "central vac" 2 8' shop vac hoses together using a dirt devil handvac hose end, i used rubber bands to attach a kirby classic cord plugged into a pigtail to power the lux PN-5 nozzle i was using with it. |
Post# 306984 , Reply# 8   11/21/2014 at 19:08 (3,442 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Post# 306989 , Reply# 9   11/21/2014 at 19:36 (3,442 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 307017 , Reply# 10   11/21/2014 at 22:52 (3,442 days old) by floor-a-matic (somewhere)   |   | |
A 50" long x 3/4" diameter dryer vent cleanout tool; better than the Lint Wizard "as seen on TV"! |
