Thread Number: 27036
Kirby Part Numbers |
Post# 302425 , Reply# 1   10/19/2014 at 21:11 (3,475 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
J.,
To answer your first question, Kirby recommends that these two armatures be used on the following Kirby models: 114959 - to be used on models 505 to 519 114960 - to be used on models 560 to S7 More recently, however, when these two armatures went out of production they then told you to use part no. 114967 which is normally used only with the two-speed machines (Dual Sanitronic 50 and 80, or D50 and D80). As to the second question, however, the other numbers you're finding may refer to the code numbers of said armatures, while Kirby gives its own part numbers for the same product. ~Ben |
Post# 302435 , Reply# 2   10/19/2014 at 22:13 (3,475 days old) by Jeschbac (Texas)   |   | |
Thanks, Ben, this is very helpful! The only number I find on the field is what I gave. What would be the best way to find out what models this field can be used for |
Post# 302453 , Reply# 3   10/19/2014 at 22:43 (3,475 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
