Thread Number: 26939
Some Columbus polishers I am restoring |
Post# 301163   10/9/2014 at 11:00 (3,458 days old) by gsheen (Cape Town South Africa)   |   | |
So I am finally getting around to restoring some of my columbus polishers I have acquired over the years.
I got this sad looking B11 in 2011.
Post# 301166 , Reply# 1   10/9/2014 at 11:30 (3,458 days old) by gsheen (Cape Town South Africa)   |   | |
This is a Older version of the B11 , The main difference between the B11 and B12 or Mark III is that the B11 cannot be converted into a vacuum.
This version uses the same motor as a B12 while newer versions used a different motor This motors spindle allen screw had rusted shut and had to be drilled out. Once off The fan is removed and then access to the motor can be had from either bottom or top. On newer motors you can oly access the motor from the top. |
Post# 301202 , Reply# 2   10/9/2014 at 16:06 (3,458 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 301221 , Reply# 3   10/9/2014 at 17:35 (3,458 days old) by gsheen (Cape Town South Africa)   |   | |
It is Bakelite. Newer versions had a polymer fan.
Here is the motor in pieces. Not in bad condition Just a little work needed and a good clean. I love these carbon brush covers |
Post# 301224 , Reply# 4   10/9/2014 at 17:45 (3,458 days old) by gsheen (Cape Town South Africa)   |   | |
Motor put back together. Body repainted and the hood rechromed
The Underside too , without spindle attached . The pad drives in place but not connected up yet |
Post# 301225 , Reply# 5   10/9/2014 at 17:47 (3,458 days old) by gsheen (Cape Town South Africa)   |   | |
All done and dlooking good.
Post# 301235 , Reply# 6   10/9/2014 at 18:26 (3,458 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
