Thread Number: 26367
questions about Hoover dial-a-matic automatic power drive |
Post# 295547 , Reply# 1   8/26/2014 at 21:16 (3,527 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Welcome! And good for you to keep an old HOOVER running strong! The hose below is what you'll need, you can get a new, non-matching one for $30 if you really want to! Be sure to use genuine bags, and I don't mean those white-paper new ones that day 'genuine Hoover'. Your best bet is to find old-stock, quality green bags on eBay. I buy them senseless whenever I see them in thrift stores! CLICK HERE TO GO TO super-sweeper's LINK on eBay |
Post# 295853 , Reply# 3   8/28/2014 at 16:04 (3,525 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Hi again! The Dial-A-Matic was part of Hoover's finest hour. Every upright in your local Wal-Mart owe many thanks to the Dial-A-Matic for one reason: the Dial-A-Matic was the world's FIRST bypass upright. Dirt goes to the bag first, then the fan. Every upright that preceded it was fan first, then bag.
Glad to see you're set on the original bags! With them, you should have no leaks in dust, true HOOVER quality! There's not much needed to keep these old workhorses in running order. You've got the bag and belt replaced, that's step one! If your machine in the ad above is a Power-Drive model, you are likely to need a new belt for it, too! Did you replace it as well with the drive belt? With a fresh belt, Hoover's infamous 'Herky-Jerky' Power-Drive comes to life! Be a bit careful around furniture, but I advise that with any self-propelled machine. Unless you have allergies, those green Type D bags will serve you well. If you do, you should be able to buy bulk filter material to cut to size. I tend to use HEPA synthetic bags for this,I can just toss out a custom filter and make a new one! I'm not sure if they made them for the Type D setup, but the only bag that can beat the original Green bags is the N.O.S Allergen bags! I run the Type A versions in my Concept I, I LOVE those bags!
Glad to see you're going for the hose, it's much more user-friendly then those horrible things they put on modern vacuums! There's not much advice to give, just twist-in the hose and 'Dial' in the suction power you want! That hose takes Hoover's legendary snap-and-lock style of tools. They have a small plastic stub on them for the handle to either snap onto or twist on. Your future hose is a twisting version. Simply turn the plastic collar on the end of the hose, it's easy to use, you'll see when it arrives! The tools that fit the hose are phenomenal, especially the upholstery nozzle with its rubber finger-thingies! GREAT on pet hair!
Oh, and almost forgot! Take a sheet of paper and place it over the brush intake. Hopefully the bristles extend out enough to barely exit the nozzle. That will ensure optimum performance!
You sound just like me, all my stuff is older than I am!
Here's a pic of the tools you'd want to look for, good luck with you D.A.M! |
Post# 296199 , Reply# 5   8/31/2014 at 01:42 (3,523 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 296705 , Reply# 7   9/2/2014 at 18:17 (3,520 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
