Thread Number: 26326
The Eureka Patriot -- A Work in Progress |
Post# 295198   8/23/2014 at 17:55 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
A couple of people have asked when I was going to post more photos. Well, I'm still not happy with its look, so I still plan to tweak it. I repainted the hood using appliance paint. Since it has an epoxy base, it takes a few days for it to dry and cure. The original color was an ivory/off white. But I was going for a cleaner look, so I chose a standard white.
The blue plastic around the headlight lens shows some scuffing, so I may repaint it too.
Post# 295200 , Reply# 1   8/23/2014 at 17:58 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
The original handle was plastic. But since I swapped the 4 amp motor for a 7 amp, I was concerned that it might put more stress on the handle. So I swapped the plastic handle for a chrome plated Sanitaire handle.
This post was last edited 08/23/2014 at 20:38 |
Post# 295201 , Reply# 2   8/23/2014 at 18:04 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
I'm not happy with the contrasting reds on the cord and handle grip. The cord came from a Kirby Classic III. I also sprayed a new handle grip with Valspar plastic paint. I've never used that brand before, and I'm not happy with it. It's been about 5 days since I sprayed it out and it still needs more curing time. I don't think it's going to be very durable, so I'm going to spray out a new grip using SEM plastic/vinyl paint. That is an outstanding paint. Very durable. And they have many more color choices too. I'm sure I can find one to more closely match the cord.
Post# 295202 , Reply# 3   8/23/2014 at 18:07 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
Since I installed a new 7 amp motor, I went ahead and upgraded to the ST bag system too. That's an easy and inexpensive change to make and it will allow me to use the Filtrete bags (which I think are better suited for the 7 amp motor).
Post# 295203 , Reply# 4   8/23/2014 at 18:17 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
The final major change was the brush roll. I took an aftermarket VGII with all bristles and I replaced half of them with VGIII bristles. The VGIII bristles have the brush stiffeners on them. I must say that the brush stiffeners help propel the vacuum along! The 7 amp motor does an excellent job of lifting the carpet into the nozzle too (probably better than my Kirbys!). It creates massive airflow between the carpet and pad. And with the VGII.5 brush roll, I think this Eureka gives superior cleaning performance!
This brush roll also does an excellent job of handling dog hair. I have two dogs, one of which is a Golden Retriever. The Retriever's hair tends to get easily wrapped around brush rolls. But the brush stiffeners seem to slough it off more easily. My only concern with this brush roll is that it may put more stress on the round belt than usual, thus shortening the life of the belt. Only time will tell.
Post# 295204 , Reply# 5   8/23/2014 at 18:19 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
All in all, I'm very pleased with the result. My main objective is to change the handle grip. When that's done, I'll be satisfied!
Post# 295208 , Reply# 6   8/23/2014 at 18:31 (3,527 days old) by sonnyndad ()   |   | |
Where did you get those? I'm entertaining thoughts of getting some for my Sanitaire since we have old matted down shag. The VGII beater bar does an outstanding job on it, but I want more. |
Post# 295219 , Reply# 7   8/23/2014 at 19:49 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
They are hard to find. This is where I got them, but I think you may be able to find them elsewhere for less money.
CLICK HERE TO GO TO eurekastar's LINK |
Post# 295226 , Reply# 9   8/23/2014 at 20:35 (3,527 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 295316 , Reply# 10   8/24/2014 at 18:49 (3,526 days old) by constellation86 (Roy, UT)   |   | |
Here are a couple pictures of the bag. Unfortunately it needs a new bellows assembly. One more thing on my to do list. Nicholas |
Post# 295318 , Reply# 11   8/24/2014 at 19:27 (3,526 days old) by eurekastar (Amarillo, Texas)   |   | |
