Thread Number: 26158
Electrolux Hose Ends |
Post# 293290 , Reply# 1   8/13/2014 at 09:26 (3,537 days old) by dysonman1 (the county)   |   | |
You'll need a wire cutter, a roll of electrical tape, and a sharp knife. Wrap the hose with the tape (to prevent the cloth from fraying) as close as possible to the machine coupling. Two turns of tape is enough. Cut the hose in the middle of the tape, and use a wire cutter to cut the wire. The old machine coupling is now free of the hose. Pull the wire from the machine coupling (along with the bit of hose still inside), and you can use Pliobond glue to glue the 'new' hose into the 'old' machine coupling. The same procedure is done with the handle end.
Post# 293298 , Reply# 2   8/13/2014 at 10:16 (3,537 days old) by kirbyduh (Kentucky )   |   | |
Thanks so much Tom!!! |
