Thread Number: 26150
Need help with my Kirby D50 |
Post# 293157   8/12/2014 at 13:24 (3,515 days old) by sptyks (Skowhegan, Maine)   |   | |
When I was restoring my D50 a few month's back, I ordered and installed a new wooden brush roll with a single row brush. I had a couple of spare belts from my Kirby Sentria hanging around, so I used one of those when i installed the new brush in the D50. Now, when I use my D50, there is a squeaking noise coming from the brush roll. So, I have the following questions:
1. Is it OK to use the G series belts on the D50? 2. If not, is it possible I may have damaged my D50 brush roll? 3. If it is not OK to use the G series belts, then what is the part number for the correct D50 belt? 4. What is the part number for the 4 row brush roll if I should decide to use that instead?
Thanks Guys for any info and help you can give me.
Post# 293180 , Reply# 1   8/12/2014 at 16:15 (3,515 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 293203 , Reply# 2   8/12/2014 at 17:51 (3,515 days old) by sonnyndad ()   |   | |
... And we came to the conclusion that it is OK to use a knurled belt only if you have a ball bearing brushroll. |
Post# 293204 , Reply# 3   8/12/2014 at 18:08 (3,515 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 293205 , Reply# 4   8/12/2014 at 18:15 (3,515 days old) by sptyks (Skowhegan, Maine)   |   | |
Post# 293206 , Reply# 5   8/12/2014 at 18:34 (3,515 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 293207 , Reply# 6   8/12/2014 at 18:38 (3,515 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Stan,
Or, you can get the rarer 500505 13" double-bristle brush roll... but make sure your Kirby parts supplier is one that orders from Steel City Vacuum, as mentioned in the last post in this thread: www.vacuumland.org/cgi-bin/TD/TD-... ~Ben |
Post# 293210 , Reply# 7   8/12/2014 at 19:17 (3,515 days old) by eurekastar (Amarillo, Texas)   |   | |
It is perfectly acceptable to use the knurled belt if the brush roll is a newer ball bearing version. The quickest way to tell which you have is to remove the brush roll and spin one of the ends. If both ends spin in unison, then it is an older brush roll with sleeve bearings. In that case, use the older soft belt.
Squeaking can be for a variety of reasons. It may be a wheel too. |
Post# 293302 , Reply# 8   8/13/2014 at 10:35 (3,514 days old) by sptyks (Skowhegan, Maine)   |   | |
