Thread Number: 26082
Eureka Upright Motor Question |
Post# 292452   8/8/2014 at 16:23 (3,546 days old) by eurekastar (Amarillo, Texas)   |   | |
Today, I dug into a Eureka Upright that I've had sitting around. It has a 4 amp motor in it. The lower bearing needs to be replaced. However, my question is about the sleeve bearing on top. What do I need to do to service it? Do I just apply some oil? If so, what kind? I guess the only way to replace it (if it needed replacing) is to replace the motor cover since it is riveted into it. Thanks!
Post# 292504 , Reply# 1   8/9/2014 at 00:20 (3,546 days old) by eurekastar (Amarillo, Texas)   |   | |
This is the part I'm talking about. The motor cover has a sleeve bearing in it. From what I can tell, this part is no longer available. Nor is the motor bottom with the ball bearing. Nor are the motor brushes (which are just fine). It's a shame to have to waste a perfectly good armature and motor field when Eureka is no longer producing other replacement parts! I have a 7 amp motor that I'm going to install. But I'd like to keep this 4 amp as a good, working spare!
Post# 293109 , Reply# 3   8/11/2014 at 23:11 (3,543 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 293372 , Reply# 4   8/13/2014 at 19:44 (3,541 days old) by vacman1961 (North Babylon, New York)   |   | |
Get rid of that wimpy 4 AMP motor and put in a beefy 7 AMP motor, you wont be disappointed. |
Post# 293379 , Reply# 5   8/13/2014 at 20:35 (3,541 days old) by eurekastar (Amarillo, Texas)   |   | |
