Thread Number: 25950
cleaning vacuum tools (i.e. bare floor brush) |
Post# 291041   7/30/2014 at 09:04 (3,556 days old) by ralph123 (Little Rock, AR)   |   | |
Just curious, do you clean your bare floor tools, and if so how? Have a Lux Ambassador III, and regularly use the bare floor brush to vacuum kitchen, bathrooms, etc. Is it safe to soak the bare floor brush? |
Post# 291044 , Reply# 1   7/30/2014 at 09:24 (3,556 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 351752 , Reply# 2   5/7/2016 at 15:37 (2,909 days old) by moderneezer (Gatineau, Quebec, Canada)   |   | |
I do clean the bristles after each time I use the floor brush, the dusting brush or one of the turbo heads for cleaning stuff, by removing dirty matters with my fingers. I sometimes use the crevice tool or the plain hose tip to clean the attachments' interiors and bristles. I never put my accessories in water nor used soap to clean them, unless if we had a wet-and-dry canister like a Shop-Vac.
Post# 351879 , Reply# 3   5/9/2016 at 11:13 (2,907 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
I usually run the hose over the brushes to clean them. This works fine. Supposedly my Wessel Werk rd285 brushless floor nozzle is dishwasher safe but have not cleaned it with water because I have not needed to. |
Post# 351908 , Reply# 4   5/9/2016 at 18:47 (2,907 days old) by fan-of-fans (USA)   |   | |
I usually use the hose end to vacuum off dusting brush, floor brush, upholstery brush, etc after using. It should be safe to wash them in soapy water, but I don't know that it would really do much to clean the bristles of dust, probably just create mud. It's worth a try, just make sure they're dry before you try to use them again.
