Thread Number: 25921
My find on this stormy Sunday |
Post# 290637   7/27/2014 at 21:56 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
$35 for it .. Works!
Post# 290639 , Reply# 1   7/27/2014 at 22:03 (3,559 days old) by Gr8DaneDad ()   |   | |
Sweet! |
Post# 290640 , Reply# 2   7/27/2014 at 22:05 (3,559 days old) by marks_here (_._)   |   | |
Post# 290641 , Reply# 3   7/27/2014 at 22:14 (3,559 days old) by kirbyduh (Kentucky )   |   | |
Looks like you have better luck in your part of Kentucky than I do in mine! Congrats on the find. |
Post# 290642 , Reply# 4   7/27/2014 at 22:15 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
Post# 290644 , Reply# 5   7/27/2014 at 22:24 (3,559 days old) by marks_here (_._)   |   | |
Post# 290645 , Reply# 6   7/27/2014 at 22:26 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
Post# 290653 , Reply# 7   7/27/2014 at 22:45 (3,559 days old) by DesertTortoise ()   |   | |
Check that out! Beautiful. Since I don't know my Filter Queens approximately what vintage is that vac? |
Post# 290663 , Reply# 8   7/27/2014 at 23:16 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
So I started it once, wasn't much suction .. Took it apart to empty the canister, it was caked with dog hair, and some dog hair in the hose I cleaned it all out .. Started again did some vacuuming, the suction was fixed, however it started to smell, I immediately turned it off. Do you think that was just it cleaning its self out completely? Kind of was a belt burning smell, the vacuum did begin to bog down, I gave it some type disconnected the attachment, turned it back on, it comes on but I went no further than 5 seconds. Just confusing as everything is cleaned out properly and the suction is fine.
Post# 290664 , Reply# 9   7/27/2014 at 23:41 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
Post# 290665 , Reply# 10   7/27/2014 at 23:50 (3,559 days old) by Brad845 (Harlan, Kentucky)   |   | |
Post# 290666 , Reply# 11   7/27/2014 at 23:52 (3,559 days old) by marks_here (_._)   |   | |
Check the brush roll to make sure there is nothing binding the ends, once that's done put some oil(not dw40) on the end, with your hand manually turn the brush making sure it turns freely. Also check the belt shaft on the motor to see if it turns easy also then put it back together, test it before putting the bottom plate back on & that should take card of it.
Post# 291193 , Reply# 12   7/31/2014 at 00:18 (3,556 days old) by Brad845 (Harlan, Kentucky)   |   | |
Silly kids .. Beautiful? Here's a closer look .. The cleaning shall start Saturday!
Post# 291196 , Reply# 13   7/31/2014 at 00:27 (3,556 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
