Thread Number: 25768
Rainbow D4c seperator removal |
Post# 289148 , Reply# 1   7/17/2014 at 09:28 (3,568 days old) by dysonman1 (the county)   |   | |
The separator will stick to the spider wheel if it's not cleaned regularly. Remove the separator nut, and use a small straight screwdriver to pry under the edge of the separator. This should break it free for removal. As the machine is 20 years (or more) old, it would be wise to have the bearings replaced and the motor serviced. I just taught my friends how to do this at the Vacuum Cleaner Collectors Group convention in June.
Rebuilding it would involve taking the motor unit completely apart down to the screws, washing everything except the armature, field, carbon brushes, and bearings. Then replacing the bearing and carbon brushes, and reassembling it. If you pay for this service at a shop, expect to pay about $150. Once rebuilt, the machine should run well for you for more than a decade. |
Post# 289246 , Reply# 3   7/17/2014 at 17:29 (3,567 days old) by eurekastar (Amarillo, Texas)   |   | |
That foam is actually a gasket. It is replaceable. You'll need to peel it off and scrape off as much of the adhesive as possible. I use 3M Emblem Adhesive to attach those things, but other types will work too. CLICK HERE TO GO TO eurekastar's LINK on eBay |
Post# 289260 , Reply# 5   7/17/2014 at 20:10 (3,567 days old) by marks_here (_._)   |   | |
Post# 289272 , Reply# 6   7/17/2014 at 20:46 (3,567 days old) by marks_here (_._)   |   | |
Post# 289297 , Reply# 8   7/17/2014 at 21:56 (3,567 days old) by marks_here (_._)   |   | |
Post# 289300 , Reply# 9   7/17/2014 at 22:02 (3,567 days old) by Gr8DaneDad ()   |   | |
Welcome back Tracy. I store my collection in the guest room... who invites guests to stay anyway? If I did, it would likely be another collector.
Stay around a bit this time
Tom |
Post# 289362 , Reply# 11   7/18/2014 at 07:20 (3,567 days old) by countryguy (Astorville, ON, Canada)   |   | |
