Thread Number: 25591
making your electrolux gleam!!! on the case |
Post# 287342   7/5/2014 at 14:32 (3,574 days old) by markanthony5 (England Isle of Wight)   |   | |
Hi guys I have found that if you use a dash board car back to black new spray for rubber trim on your plastic dash it also does wonders on your cylinder vacuum cleaners.After you have cleaned them of course
This stuff of-course is a clear polish not black just makes rubber and plastic look new Not on the plastic trim but on the cylinder covering seems to last about a month or two,but not on the carry handle as it can make it a little slippery. But on the body of the vac scratches and slight marks vanish and almost looks new After a month or two have gone by i simply wash with a damp cloth and soapy water and respray but the vinyl covering only I only use the matt version as the shiny look looks tacky and obvious and horrible Ive also found that auto sol works wonders on plastic parts helps remove deep scratches as does T cut for cars The second pic is the product i have been useing. Like on my z65 |
