Thread Number: 25317
Oreck XL7 cloth outer bag... Can it be washed?? |
Post# 284540 , Reply# 1   6/14/2014 at 08:09 (3,601 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Oreck themselves used to say that their outer bags were washable, as long as you can remove the bottom clip with the name plate on it, if applicable. I think there's a spring or something that keeps it attached to the main spine. I don't see why it can't be washed in a machine though I'd remove the name plate first if you can. Choose a low temp program and put it in. |
Post# 284542 , Reply# 2   6/14/2014 at 08:11 (3,601 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
Also, forgot to say, check that the bag can actually be removed completely - this might take some time if the bag housing is behind it. If it is bonded on, then you may well just have to sponge clean the bag rather than machine washable.
Id have assumed the XL7 has a far easier bag to remove off the vacuum cleaner as it is far more modern than the XL I used to own. |
Post# 284549 , Reply# 3   6/14/2014 at 08:41 (3,601 days old) by sebo_fan (Scotland, UK, member AKA ukvacfan, & Nar2)   |   | |
