Thread Number: 25301
Electrolux XXX low suction |
Post# 284256   6/12/2014 at 17:51 (3,604 days old) by floor-a-matic (somewhere)   |   | |
Is the XXX supposed to have VERY little suction? I tried the turbo brush test & the brush was barely spinning. The XXX has a newer coiled PVC vinyl hose & NOT the woven hose. |
Post# 284276 , Reply# 3   6/12/2014 at 23:07 (3,604 days old) by tig21er (Indiana)   |   | |
style fans were big on metal fatigue and they bend and break also check the Rubber motor mount for drying out and being cracked. |
Post# 286988 , Reply# 4   7/2/2014 at 21:30 (3,584 days old) by floor-a-matic (somewhere)   |   | |
Not to mention, but its hardly blowing air thru the exhaust
The hose port gasket has deformed as time passed by
Where can I find the bumper & rubber "donut" for the dusting brush? |
Post# 286991 , Reply# 5   7/2/2014 at 21:37 (3,584 days old) by Jaker15 (Meridian, ID)   |   | |
Have a model XXX, and it doesn't have incredible suction, but it's pretty good for what it was in 1949, if you ask me. I did replace the hose it had with a new one, and it still is not a powerhouse. It does have a lot of airflow, however, and cleans carpets pretty nicely for such an old machine. I will have to tear into the motor and check the fans one of these days just to be sure everything's okay.
Post# 286994 , Reply# 6   7/2/2014 at 21:54 (3,584 days old) by Gr8DaneDad ()   |   | |
floor-a-matic, link to an aftermarket replacement bumper for the XXX dusting tool. CLICK HERE TO GO TO Gr8DaneDad's LINK |
Post# 286995 , Reply# 7   7/2/2014 at 22:23 (3,584 days old) by floor-a-matic (somewhere)   |   | |
Thanks for the link! I didn't know that the rubber bumper/"donut" was still made
Post# 290122 , Reply# 8   7/24/2014 at 21:58 (3,562 days old) by floor-a-matic (somewhere)   |   | |
Exhaust filter crumbled; I think this may actually be the cause for the XXX low suction. Will put in a new exhaust filter after giving the XXX a spa treatment. |
Post# 290165 , Reply# 9   7/25/2014 at 07:17 (3,561 days old) by s31463221 (Frenchburg, KY)   |   | |
Erik,
If the filter was in such bad shape to the point it crumbled on it, then it could very well have been restricting the motor so much it was affecting performance. I curious, you said you would replace the filter after you gave the machine a spa treatment. Do you have NOS filters, or are you making your own? My XXX that I use all the time has a great filter in it, but some of the others in my collection, well let's just say they are not the greatest in the world. I only have like two or three spare filters and I'm pushing close to (if not exceeding, I've lost count) 100 XXX's I obviously don't want to be swapping filters between units! |
Post# 292598 , Reply# 11   8/9/2014 at 17:08 (3,546 days old) by ronni (USA)   |   | |
Additionally, check to ensure that the two screws on the inside of the hose inlet are tight. A service tech advised me that many become loose over the years. The photo below illustrates: |
Post# 347783 , Reply# 14   3/17/2016 at 05:53 (2,960 days old) by vacerator (Macomb Michigan)   |   | |
good suction with the hose off. It had been repaired at some point, and is obviously restricting air flow. |
