Thread Number: 25170
Hoover Decade 80 Hot Belt |
Post# 282838   6/2/2014 at 21:32 (3,609 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
I bought a freshly rebuilt Decade 80 from a local vac store back in March. Great vacuum. But the belt gets so hot. I snapped one the other day and i can smell rubber burning on the new one already. Am I installing the belt wrong? Thjs js my first Hoover. Always owned Kirbys and Eurekas. I paid $150 for it, so I want to know what's wrong. It has a year warranty on it. I love how powerful it is and the Type A bags are amazing. What could be the issue?
Post# 282840 , Reply# 1   6/2/2014 at 21:36 (3,609 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
That's likely more than the cleaner cost new-But it is a true HOOVER!
If it was truely rebuilt-Then you must be installing the belt wrong, or even inside-out for all I know. using GENUINE HOOVER parts will always ensure peak performance-The word "HOOVER" should be facing out on a genuine belt. There should be a metal plate on the inside of the belt and air-flow channel. Install the belt so that the lower part of the belt is rested slightly above this.
Hope this helps, and if it doesn't, Make use of that warrenty! |
Post# 282846 , Reply# 2   6/2/2014 at 21:51 (3,609 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 282848 , Reply# 3   6/2/2014 at 21:55 (3,609 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 282851 , Reply# 4   6/2/2014 at 22:13 (3,609 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 282868 , Reply# 5   6/2/2014 at 23:22 (3,608 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 283030 , Reply# 6   6/4/2014 at 06:10 (3,607 days old) by Gr8DaneDad ()   |   | |
Have it serviced under warranty. The brushroll should spin freely with the belt removed. |
Post# 283109 , Reply# 7   6/4/2014 at 14:44 (3,607 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 283113 , Reply# 8   6/4/2014 at 15:06 (3,607 days old) by Vinvac (Dubuque IA)   |   | |
Post# 283127 , Reply# 9   6/4/2014 at 16:02 (3,607 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 283893 , Reply# 11   6/9/2014 at 17:57 (3,602 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 283949 , Reply# 13   6/10/2014 at 09:13 (3,601 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 283951 , Reply# 14   6/10/2014 at 09:48 (3,601 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
Post# 283953 , Reply# 15   6/10/2014 at 10:09 (3,601 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 283954 , Reply# 16   6/10/2014 at 10:19 (3,601 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
Post# 283969 , Reply# 17   6/10/2014 at 12:26 (3,601 days old) by bnsd60m9200 (Akron OH)   |   | |
cwp brushrolls are absolute crap on convertibles. get an actual metal hoover brushroll with beat bar. brush strips are still easy to find for them and the bearings are servicable. cwp brushrolls for convertibles have a bad reputation of overheating motor bearings, esp on the old metal based machines.
Post# 283981 , Reply# 18   6/10/2014 at 15:02 (3,601 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 284025 , Reply# 19   6/10/2014 at 20:44 (3,601 days old) by super-sweeper (KSSRC Refurbishment Center)   |   | |
Post# 284041 , Reply# 20   6/11/2014 at 01:12 (3,600 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 284058 , Reply# 21   6/11/2014 at 09:36 (3,600 days old) by bvac6 (Fort Wayne, Indiana)   |   | |
Post# 284062 , Reply# 22   6/11/2014 at 10:44 (3,600 days old) by marks_here (_._)   |   | |
Okay this is what my vacuum man told me, the new oem hoover belts are made a bit smaller then years ago with a stronger rubber compound thus it being hard to stretch over the shaft if you can get it over it & once on the roll rush would barely spin & the motor was struggling to turn. He has had many complaints from customers with old machines burning up motors so he started using eureka belts which solved the problem. You might want to try this to see if this fixes it, if not try rebuilding the old brush roll, they will last better then the new plastic ones. Hope this helps. Cheers!! Mark D.
Post# 284123 , Reply# 24   6/11/2014 at 22:13 (3,600 days old) by smow69 (Muskogee Oklahoma)   |   | |
sometimes the decade body where the roller sits gets worn also you might check that i have had two or three this way. |
Post# 284145 , Reply# 25   6/12/2014 at 00:00 (3,599 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
Post# 284176 , Reply# 26   6/12/2014 at 10:21 (3,599 days old) by HooverCelebrity (Germany)   |   | |
What kind of carpet do you have, and which carpet-height setting are you running the machine on? |
Post# 284231 , Reply# 27   6/12/2014 at 16:02 (3,599 days old) by firebirdman55 (Owensboro Kentucky)   |   | |
