Thread Number: 25100
Hoover spectrum 900 hose wiring |
Post# 282508 , Reply# 1   5/31/2014 at 12:29 (3,616 days old) by Durango159 (State College, PA)   |   | |
The Spectrum Canister was a TOL model. There are 3 prongs from power nozzle to hose and 3 prongs from suction unit to hose, depending on the model.
The Spectrum canister has the Quadraflex Powermatic nozzle which has a toe operated bare floor switch which on the Dimension 1000 series kept the headlight on if brush roll motor was turned off. The PowerMax units have a PowerMax power nozzle with no foot pedal. The 3rd wire on hose of PowerMax units is to run electric for headlight if bare floor position was selected on switch on hose. The PowerMax series has a wide range of units. Some have a T shaped plug but only 2 electric prongs and NO hose controls. Others such as the TOL PowerMax Ultra S3620 or S3611 have 3 prong connections to suction unit and power head with controls on hose for variable suction speed, brush roll on/off and entire system on/ off. Depending on which PowerMax model you have you may need an entirely different hose. I definitely do not recommend cutting off any prongs or the 3rd connector. You don't want to mess up any internal boards inside units or short out any parts. I love the PowerMax series to Windtunnel series. Machines I've owned: PowerMax Runabout S3614, PowerMax Deluxe S3608, PowerMax Deluxe S3607, PowerMax S3603-040, PowerMax Supreme S3530, Turbo Power 5000 S3577, Windtunnel S3630, Windtunnel Plus S3639, PowerMax Deluxe S3601. |
Post# 282524 , Reply# 2   5/31/2014 at 13:48 (3,616 days old) by rugsucker (Elizabethton TN)   |   | |
I am finding more hoses that may be better for that model.Don't pull prongs out yet.Other plastic Hoover will go in dumpster for lack of interest.I then hope to sort wands,hoses & power nozzles that are also turning up. Jimmy |
