Thread Number: 25069
Central vacuums |
Post# 281812   5/25/2014 at 17:36 (3,621 days old) by gsheen (Cape Town South Africa)   |   | |
So I recently acquired a vacu flow central vac unit. I am not familiar with this brand, I have never seen one before here in SA. While we do get them, I have one aswell, I am very familiar with Beam & Vacumaid, MD systems are also available here , They are Not popular here because our houses are concrete and brick here they are not popular as the expense of fitting them to a ready built home is massive.
Here are my questions. The unit is well used but in good condition. I was amazed as the unit is cyclonic but has no prefilter to protect the motor from fine dust. If it used a dirty fan motor like a convertible or Kirby I would not foresee any problems, But it uses a standard tangeltal by[ass motor like those found in 99% of portable carpet cleaners. These use the same style fans found in most standard twin stage through flow motors and if you have worked in the vacuum business enough you will know that fine dust that gets past filters or from burst bags causes these fans to get out of balance and vibrate the whole motor. The cyclone set up on this unit is not very sophisticated and as such should cause fine dust to build up in the turbines.
What I would like to know is what is the durability of these machines like ?
Post# 281885 , Reply# 2   5/26/2014 at 06:06 (3,621 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 281889 , Reply# 3   5/26/2014 at 06:48 (3,621 days old) by singingrainbow (Texas)   |   | |
No, I have never actually heard of anyone trying that, you could be the first! That's interesting that all systems are vented outside in SA, most all the systems we install are not. Scott |
Post# 281904 , Reply# 4   5/26/2014 at 09:11 (3,621 days old) by gsheen (Cape Town South Africa)   |   | |
Post# 281944 , Reply# 5   5/26/2014 at 16:21 (3,620 days old) by gsheen (Cape Town South Africa)   |   | |
Here are some pics of the Motors between the Beam left hand side and the Vacuflow right . Both Using amatek motors. The beam using the newer curved fan Giving a bit more suction. |
Post# 281945 , Reply# 6   5/26/2014 at 16:33 (3,620 days old) by gsheen (Cape Town South Africa)   |   | |
For those who don't or haven't seen, The view from the motor casing down to the bottom of the tank. For some one like me who appreciates cyclonic action this scares me a bit. That said, The motor shows very little dust build up inside and between the two the Beams silencer although bigger was dirtier
Post# 283178 , Reply# 8   6/4/2014 at 21:41 (3,611 days old) by marks_here (_._)   |   | |
I hope they last a lot longer, I just had one installed in my house the 466Q which is simply amazing how much it picks up!!! I have a Maine coon cat that shed a lot & got tired of my Sentria so it is so much easier to put the hose in the wall & go. I had them install it higher on the wall so I can check the screen every 2 weeks, I was told the same thing, keep the screen clean & empty it half full, so far since the install which was 2 months ago it has 1/3 of the 6 gallons full. I still can't get over how much it picks up! Cheers!!!! Mark D.
Post# 283217 , Reply# 9   6/5/2014 at 00:55 (3,611 days old) by bimmer740 (Long Island, New York)   |   | |
I have had a VacuFlo 566Q for more than 7 years now and I love it! I actually bought it from Charlie's (vacman1961) vacuum store. I only empty the bin about every 5-6 months but when I empty the bin I simply vacuum the screen in the unit with another vacuum. My house is almost entirely bare floors with only 3 rooms having wall to wall carpet, which get vacuumed with a Kirby more often then the central vacuum, so my machine doesn't get filled with carpet fiber and fluff. I've had a Lindhaus power nozzle for a while now but I'm not crazy about it. It's nice to be able to mix and match attachments to whatever suits your own needs. My unit came with a lifetime warranty and its well cared for so I'm not too worried about any motor issues occurring. I do love not having to buy bags or filters and knowing all the dirt is leaving our living space. One other nice feature is the unit is quiet, it's rated somewhere around 66 decibels and with the unit being in the basement you can barely hear it running, you just hear the fantastic suction power. It's certainly the best vacuum purchase I've ever made!
Post# 286061 , Reply# 10   6/24/2014 at 14:57 (3,591 days old) by gsheen (Cape Town South Africa)   |   | |
Hey every one, Thanks for all the feed back.
So I hooked this thing up in my workshop at the office. I could see the outside vented exhaust and noticed when I was using it to vacuum up the dust out of other vacuums it was making a huge could outside. Now granted this is would not be a normal household situation but its nothing my beam at home doesn't handle when I use it in my workshop to suck up my woodworking dust or cleaning out a old vintage vacuum.
I like the idea of the cyclonic central vac, It means it wont clog and loose suction like my beam does when I suck up to much fine dust But I spend enough time keeping the dirt from outside my house from getting in( vacuuming my paving and stuff, The last thing I want is the vacuum to be depositing the dust I just vacuumed up just on the other side of a wall. The cyclone is just not efficient enough to remove fine dust( something that James dyson struggled with for a long time before inventing the dual cyclone )
Is their a filter option for the vacuflow
Is their a filter option |
Post# 286172 , Reply# 12   6/25/2014 at 10:15 (3,590 days old) by marks_here (_._)   |   | |
