Thread Number: 24979
Kirby Field Coil Stator Field Terminal U-Clip Help :) |
Post# 280890   5/17/2014 at 20:28 (3,625 days old) by chicagomike (Plover, WI)   |   | |
HI!
Can someone tell me how to safely remove the Field Terminal U-Clip's from the motor housing/carbon brush sleeve/holder? The wire for the Field Terminal U-clip's are attached to the Field Coil/Stator and I would like to remove the Field Coil so I can clean the inside of the motor housing, plus removing this ensure no wires are sticking out of the motor housing so there will be no chance of the wires getting wrapped in my buffer. If you know of the tool needed to pry it off and the tool need to re-install the clip, I sure would appreciate the help in accomplishing this! The u-clips cost about $10 each so directions you can give me to accomplish sure would be appreciated! Attached is a picture of the part I am referring to as well :) |
Post# 280895 , Reply# 1   5/17/2014 at 21:26 (3,625 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 280896 , Reply# 2   5/17/2014 at 21:28 (3,625 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 280932 , Reply# 3   5/18/2014 at 08:46 (3,624 days old) by BikerRay (Middle Earth)   |   | |
Post# 281296 , Reply# 4   5/21/2014 at 09:11 (3,621 days old) by chicagomike (Plover, WI)   |   | |
