Thread Number: 24673
I found a gem at the Flea Mall! |
Post# 276698 , Reply# 1   4/17/2014 at 13:57 (3,661 days old) by sonnyndad ()   |   | |
Oops. Model D not D4. Stupid mistake. |
Post# 276709 , Reply# 2   4/17/2014 at 14:21 (3,661 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 276739 , Reply# 3   4/17/2014 at 15:53 (3,661 days old) by sonnyndad ()   |   | |
It is definitely a Model D. The plate says so. |
Post# 276780 , Reply# 4   4/17/2014 at 18:44 (3,660 days old) by kenkart ()   |   | |
An EXPERT to rebuild this...probably one of the most difficult machines to work on ever made....good though! |
Post# 276784 , Reply# 5   4/17/2014 at 19:55 (3,660 days old) by sonnyndad ()   |   | |
Could anyone give me some assistance? |
Post# 276791 , Reply# 6   4/17/2014 at 20:15 (3,660 days old) by BikerRay (Middle Earth)   |   | |
If you're replacing the bearings
The nut that is on top of the spider needs to come off, then take the spider off. You will be able to get to the lower bearing. Most likely you will have to push the bearing out from the motor side unless it is loose in the casting (Highly unlikely) The upper bearing is mounted in a bearing plate under the fan assembly. To get to this you will need to take the top fan housing off so it will be easier to get to the nut that holds the fans on. This nut is a left hand thread. Once you get the nut off then you can take each fan and spacer off. When you get to the bottm fan underneath that is the bearing plate held on to the motor housing by several screws. The bearing plate will slide off the armature. You can either (1)get a new bearing plate with the bearing or (2)drill out the rivets and replace the bearing then pop rivet the bearing retainer back on. Then you can put it all back together. I've done several of the D, D2 and D2A series. Have fun playing in the mud. |
Post# 276792 , Reply# 7   4/17/2014 at 20:18 (3,660 days old) by BikerRay (Middle Earth)   |   | |
Post# 276797 , Reply# 8   4/17/2014 at 21:02 (3,660 days old) by sonnyndad ()   |   | |
Is it possible to repack the bearings with White Lithium Grease? This is my first Rainbow teardown, and I DON'T want to screw this this up permanently. I'm used to working on Old Kirbys. |
Post# 276866 , Reply# 9   4/18/2014 at 08:21 (3,660 days old) by BikerRay (Middle Earth)   |   | |
If the bearings are open face, yes.
If the bearings have a plastic or metal cover over the balls of the bearing, not unless you want to try and get the protective cover off of the bearing. There will be a metal piece over the bearing with what is called a slinger, it kind of runs in grease and is there to keep water out of the bearings. By the way, if it helps, if you go to Rainvac's web page you can download a schematic for the D/D2. |
